Too much transmission fluid??
Old Mar 11, 2005 | 10:37 AM
85mm LS VTEC's Avatar
Default Too much transmission fluid??
Is it possible to put in too much MTF in a B-series tranny case? I found a hole on top to pour the fluid inside the tranny instead of from the bottom. Will any damage occur?
Old Mar 11, 2005 | 11:13 AM
HGZ's Avatar
HGZ
Default Re: Too much transmission fluid?? (85mm LS VTEC)
are you talking about removing the speed sensor? thats what i did when i replaced my axles. i stuck a long funnel down there and filled it with 2.5 qts of MTF. i read on a write-up that B-series take 2.5 qts. dumped that in there, replaced the speed sensor and i was done just like that
now that i think about it, i think i was supposed to remove a rubber 'breather' cap before i filled it through the speed sensor hole, but i didn't. oh well, she drives like normal so i don't think it mattered too much. i'll remember next time.
Old Mar 11, 2005 | 01:06 PM
virusiidx's Avatar
can't you just fill it up until it spills outta the hole on the side?
Old Mar 11, 2005 | 01:11 PM
.water's Avatar
Default Re: (virusiidx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by virusiidx &raquo;</TD></TR><TR><TD CLASS="quote">can't you just fill it up until it spills outta the hole on the side?</TD></TR></TABLE>
...u can do that too...or bring out flashlight and look into hole
Old Mar 11, 2005 | 02:53 PM
Tchleung's Avatar
Filling it till the fluid is at the edge of the hole by the axle is acutally the proper level.
mayfly
May 31, 2010 05:58 AM
luv2boost
Aug 8, 2007 08:10 PM
aser1z
Sep 7, 2005 08:17 PM
Utilitarian
Feb 14, 2005 01:04 PM
