Head Overporting
Old Mar 11, 2005 | 06:03 AM
Footwork's Avatar
Default Head Overporting
Is it possible to have a head ported "too much" for a given cam?
Say you had a head specially ported for JUN III cams, then you used that same head later on with Toda A or Spoon cams.
Would the lesser cams lose more power than they normally would (meaning loss of power from the porting, not the fact that the cams themselves are less aggressive)?
Road Race application.
Old Mar 11, 2005 | 06:16 AM
phatrick2332's Avatar
Im pretty sure you dont port to match cams, you port for maximum flow of your given head.
Old Mar 11, 2005 | 07:09 AM
EKhatch's Avatar
Default Re: Head Overporting (Footwork)
You can port a head to match a cam as far as trying to make power in a given rpm range.
Old Mar 11, 2005 | 07:20 AM
00Red_SiR's Avatar
All Motor Mentor
It is totally possible to over port a head and lose power. If you ported a head for an aggressive cam and switched back to a mild cam I could see it affecting power for sure. How much depends on how heavily the head was ported.
Old Mar 11, 2005 | 09:36 AM
hybrid_vtec's Avatar
Default Re: Head Overporting (EKhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EKhatch &raquo;</TD></TR><TR><TD CLASS="quote">You can port a head to match a cam as far as trying to make power in a given rpm range. </TD></TR></TABLE>
Very True, I am having a head ported now so it will flow perfectly for my other motor which will be using Crower 405's.
Old Mar 11, 2005 | 10:50 PM
orng1's Avatar
Default Re: Head Overporting (hybrid_vtec)
yes you can port to big, I did this a long time ago when I was first taught to port. on an early b16 the car was laggy but when the vtec kicked in it really kicked ***. every one thaught the car was on NOS. other than when the big cam was on the car sucked and got poor milleage. be careful porting or take it to an experienced engine builder and let him know all the mods that the car will be running. good luck
Old Mar 13, 2005 | 05:04 AM
Grand's Avatar
the biggest problem ive seen with head porting is fuel puddling some people leave the intake side smooth as a babys *** and your head is fucked i had a guy port a head for a b18c5 and when i picked it up i basically had to throw it in the garbage
Old Mar 13, 2005 | 08:36 AM
Default Re: (LG_R32)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LG_R32 &raquo;</TD></TR><TR><TD CLASS="quote">the biggest problem ive seen with head porting is fuel puddling some people leave the intake side smooth as a babys *** and your head is fucked i had a guy port a head for a b18c5 and when i picked it up i basically had to throw it in the garbage</TD></TR></TABLE>
The intake ports need to be rough, but the exhaust ports can be smooth though, right?
Old Mar 13, 2005 | 12:08 PM
Grand's Avatar
Default Re: (hybrid_vtec)
yes the exhaust the smoother the better but the intake has to be rough for the fuel to atomize properly
Old Mar 13, 2005 | 12:22 PM
danimal's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Footwork &raquo;</TD></TR><TR><TD CLASS="quote">Is it possible to have a head ported "too much" for a given cam?</TD></TR></TABLE>
yes, it is... head flow vs. displacement sets the power band of the motor, so you want a camshaft that'll match that... see if this thread makes sense: https://honda-tech.com/zerothread?id=698160
spoonek9
Apr 13, 2006 06:38 PM
Lewdin' Incognito
Jul 22, 2005 12:35 AM
legendboy
Apr 13, 2002 01:50 PM
