dont need a crank sensor on hybrid?
Old Mar 11, 2005 | 04:01 AM
EKB18BPR3's Avatar
Default dont need a crank sensor on hybrid?
i have a obd2 EK with obd1 b18b. currently im using obd2 dist to plug straight into the engine harness. the timing belt snapped on my way to work and ripped the crank sensor at the crank pulley. instead of replacing the crank sensor, if i slap on a obd1 distributor, can i elimnate the crank sensor?
Old Mar 11, 2005 | 06:59 PM
EKB18BPR3's Avatar
Default Re: dont need a crank sensor on hybrid? (98B00STED)
bump for an answer peeeeeze
Old Mar 13, 2005 | 07:22 PM
VTECVillain's Avatar
The crank sensor by the crank pulley you are referring to is the crank fluctuation sensor but it doesn't have anything to do with the distributor. If you have an OBD1 B18B then it should not have that sensor unless the oil pump was switched to an OBD2 oil pump and then the sensor was added. If you are using an OBD1 ECU, it doesn't look for a crank fluctuation sensor so you won't have to worry about it.
akinas-crx
Oct 28, 2011 06:00 PM
jjmcmana
Nov 1, 2008 09:02 AM
teddy_dc2
Oct 4, 2007 07:54 PM
Spence
10
Apr 24, 2006 09:37 PM
blowbyu24
Oct 24, 2005 09:53 AM
