CEL diagnostic help
Old Mar 11, 2005 | 12:41 AM
Keebler's Avatar
Default CEL diagnostic help
Hello all.
Here is the situation -
B16A1 w/ obd0 - Factory install, (EE8) Crx
Couple weeks ago, had the dizzy lock up on me. Got a used dizzy from an H-T member couple days ago, and threw it in. New cap/rotor etc...
Now, im getting a CEL Code 9 - According to most documentation i can find, that means cylinder position, or some such... and isnt very explanatory.
The catch is, when the dizzy locked up, so did the intake cam. It jumped about 4 teeth, so I had to reset the cam to tdc. Everything looked fine when setup was finished. The car drives fine, a little boggy, but im thinking its cause i havent thrown a timing light on it yet (more just an eyeball, yea its in the center, type timing ) I also get a tach jump about 7k, and VTEC is still engaging @ the proper time.
Any ideas as to what may be causing this CEL?
Old Mar 11, 2005 | 03:15 AM
GreenBean's Avatar
Default Re: CEL diagnostic help (Keebler)
Possibly a bad distributor, Isn't the sensor for that code in the distributor???
Old Mar 11, 2005 | 04:21 AM
4gCRX's Avatar
By "in the center" I gather you set it at 16 degrees not tdc which is the white mark all by itself
Keebler's Avatar
Default Re: CEL diagnostic help (GreenBean)
I have no idea where the sensor that sends that CEL is located.
I rechecked my mechanical timing (cams/crank) and im dead on. Reset the ecu and still throw the code instantly.
Anyone? Im noticing a dead top end, im not able to hit 8k rpm near as quick.
If its the distributor, id like to know for sure, since I just bought it from a HT member who said it was gtg.
Old Mar 11, 2005 | 04:28 AM
Keebler's Avatar
Default Re: CEL diagnostic help (4gCRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4gCRX &raquo;</TD></TR><TR><TD CLASS="quote">By "in the center" I gather you set it at 16 degrees not tdc which is the white mark all by itself</TD></TR></TABLE>
By "in teh center" i mean i set the dizzy cetered on the bolts opposing the head.
I dont have a timing light atm, gonna have to wait for the autoskill center to open and go borrow one.
Either way, i could retard/advance the whole spectrum and still never throw a code 9 CEL if all was working properly.
This is why i need to know wtf this code is, and what sensor initiates it.
Old Mar 11, 2005 | 05:17 AM
4gCRX's Avatar
Helms Manual... http://www.carenthusiast.com/c...t.pdf
PGM-FI Control System &gt;Troubleshooting Flowchart&gt;TDC/Crank/CYL Sensors
Old Mar 11, 2005 | 08:33 AM
Keebler's Avatar
Default Re: (4gCRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4gCRX &raquo;</TD></TR><TR><TD CLASS="quote">Helms Manual... http://www.carenthusiast.com/c...t.pdf
PGM-FI Control System &gt;Troubleshooting Flowchart&gt;TDC/Crank/CYL Sensors</TD></TR></TABLE>
Awesome, thank you. I happened to have the helms here, and didnt think to lookin the troubleshooting guide.
Let me take a look through here and see what I can come up with.
mortificationrock
Mar 21, 2011 10:21 AM
rdeezy78
May 23, 2008 06:37 PM
SiRndX
Feb 28, 2007 06:30 PM
409-Ef8
Jan 22, 2007 03:24 PM
SweetChin
Jan 8, 2003 04:38 PM
