Still Leaking
I changed my oil pan gasket thinking it was the problem but it wasn't. Now I am wondering if there is any way it is easy to check if it is the main seal or front seal?
If it is the rear main seal, there should be oil leaking from the crease where the tranny and engine join together (right b/w the bellhousing and the block). If it is the front seal the oil should come from the front of the engine (timing belt area) it could also be your cam seal, find out if it was changed the last time your timing belt was changed, if not that is a probable cause. I hope this helps, let us know how it goes!
[Modified by iceburgslim, 12:56 AM 1/25/2002]
raverx3m
Dec 27, 2011 02:13 AM
screamo
11
Feb 28, 2005 10:43 AM
ID_ten_T
Feb 4, 2004 08:27 PM
