oil leaking from timing belt. help?
so i bought this '99 coupe EX not too long ago. it has a bone stock SOHC vtec motor and it runs fine. but in the past few weeks ive noticed it has been leaking some oil in my parking spot. and at first i thought it was from my drain plug, but i tightened it and its still leaking oil. so i checked the thread on the oil pan, because maybe the threads are weak, but thats not the problem either. eventually i find out the oil is leaking from the timing belt area, and i dont know why...does anyone know how i should fix this? should i replace the belts, or something? im not losing too much oil per day, but id rather fix it before it becomes a real hassle. its my first car, so im trying to learn what i can about it.
Re: (Lmgrcivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lmgrcivic »</TD></TR><TR><TD CLASS="quote">had to be the crank seal SOHC dont have a cam seal </TD></TR></TABLE>
Incorrect:
#21 is the cam seal
Incorrect:
#21 is the cam seal
Re: (Lmgrcivic)
Re: (Lmgrcivic)
douche bag lol
douche bag lol
Re: oil leaking from timing belt. help? (screamo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by screamo »</TD></TR><TR><TD CLASS="quote">so i bought this '99 coupe EX not too long ago. it has a bone stock SOHC vtec motor and it runs fine. but in the past few weeks ive noticed it has been leaking some oil in my parking spot. and at first i thought it was from my drain plug, but i tightened it and its still leaking oil. so i checked the thread on the oil pan, because maybe the threads are weak, but thats not the problem either. eventually i find out the oil is leaking from the timing belt area, and i dont know why...does anyone know how i should fix this? should i replace the belts, or something? im not losing too much oil per day, but id rather fix it before it becomes a real hassle. its my first car, so im trying to learn what i can about it. </TD></TR></TABLE>
did u try changing the washer on the drain plug? it's a special crush washer that's supposed to be replaced with each oil change.
ID_ten_T
02-04-2004 08:27 PM
mike2016
08-23-2002 05:13 AM
