search for itr rev limiter returned nothing useful
Old Mar 10, 2005 | 06:18 PM
MOVE OVER's Avatar
Default search for itr rev limiter returned nothing useful
i know that the rev limiter is supposed to be at 8500 rpm on the itr if i remember correctly- cutting fuel. my question is why can u drive it past that point in gear, and rev it past that when not in gear
my friends itr is not stock, but i know it is not chipped. when getting on it pretty hard going from 2nd to 3rd gear, he mis shifted and did not get it into 3rd, just popped out i guess. anyway, the engine reved over 9k rpm's.
if the rev limit is around 8500, and the engine was not shifted into a lower gear to make the engine speed to go any faster, why will it rev past redline at all?
or maybee im just dumb
Old Mar 10, 2005 | 06:21 PM
Mires's Avatar
Default Re: search for itr rev limiter returned nothing useful (KGsITR)
Well for one thing the stock tach isn't completely dead on.
Old Mar 10, 2005 | 06:22 PM
Haleiwa-Brando's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KGsITR &raquo;</TD></TR><TR><TD CLASS="quote">i know that the rev limiter is supposed to be at 8500 rpm on the itr if i remember correctly- cutting fuel. my question is why can u drive it past that point in gear, and rev it past that when not in gear
or maybee im just dumb </TD></TR></TABLE>
It is still very possible to over rev any engine.
Old Mar 10, 2005 | 06:45 PM
MOVE OVER's Avatar
Default Re: search for itr rev limiter returned nothing useful (Haleiwa-Brando)
stock tach is not accurate? nvr heard that before explain.
can someone please explain how and why it over revs? i would like to learn something out of this
no fuel, dont think there is any spark, not going in a lower gear, how does the engine turn faster still?
Old Mar 10, 2005 | 07:21 PM
Mires's Avatar
Not exactly accurate. Its usually 300 or 400 rpm off. Rev limiter is at 8400 but mine will show to rev up to 8800 or so. If it is going over that than im not sure.
Old Mar 10, 2005 | 07:23 PM
01ITR#173DC2ning's Avatar
From: Somewhere in a DC2.... Supporting the ITR Militia, USA
Mine will show 8800 as well
Old Mar 10, 2005 | 09:45 PM
Gee3's Avatar
From: Formerly of SF moved to DFW and now back in SF, CA, USA
Default Re: (01ITR#173DC2ning)
Okay someone explain this better than me... but in a non-technical nutshell...
The engine can still over-rev "mechanically". Meaning if you accidentally shift to a lower gear at high revs the engine (crank, etc) can over-rev. The Fuel cut-off or rev-limiter is just a limiter on the fuel and, I think, the spark. Meaning, no fuel after 8400rpm. But the engine can still spin much higher if you accidentally downshift incorrectly or on accident at high rpm's. Of course if that happens you can blow your engine, bend valves and rods and so on.
Hopefully someone can more eloquently re-state this for you.
And my rpm's were off by about 200rpm's. In fact, my speedo was off by a few mph as well. The stock gauges aren't always accurate.
Hope this helped!
Old Mar 10, 2005 | 09:58 PM
330R's Avatar
Default Re: (Gee3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Gee3 &raquo;</TD></TR><TR><TD CLASS="quote">Okay someone explain this better than me... but in a non-technical nutshell...
Hope this helped!</TD></TR></TABLE>
Very true. The fuel cutoff is at 8500RPM though.
However I think the thread starter was referring to over revving in neutral. He said his friend misshifted but did not engage a gear.
I just don't know if you can over rev in neutral or if you hit the fuel cutoff, because I've never tried it.
Old Mar 10, 2005 | 10:12 PM
justahobbie's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 01ITR#173DC2ning &raquo;</TD></TR><TR><TD CLASS="quote">Mine will show 8800 as well</TD></TR></TABLE>
as will mine
Old Mar 10, 2005 | 10:20 PM
nightrider's Avatar
http://www.we-todd-did-racing....DE%3D
here's a video of revving in neutral. i'm just making this thread more interesting. someone chime in who remembers this video and tell me what mods are done to the car as it may answer this thread poster's question.
Old Mar 10, 2005 | 10:32 PM
330R's Avatar
Default Re: search for itr rev limiter returned nothing useful (nightrider)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nightrider &raquo;</TD></TR><TR><TD CLASS="quote">http://www.we-todd-did-racing....DE%3D
here's a video of revving in neutral. i'm just making this thread more interesting. someone chime in who remembers this video and tell me what mods are done to the car as it may answer this thread poster's question. </TD></TR></TABLE>
well I remember the video, and whose car it was (sgT's), but I don't know the mods.
Seems to have hit a rev limiter though.
https://honda-tech.com/zerothread?id=233651
Old Mar 10, 2005 | 11:57 PM
#1151's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Haleiwa-Brando &raquo;</TD></TR><TR><TD CLASS="quote">
It is still very possible to over rev any engine.</TD></TR></TABLE>
people assume that if you mis-shift that it wont go past redline either...they think they are totally safe having a rev limiter for some reason. but anyways, he probably tricked the ecu thinking it was going to stay in gear, and it went all the way up there. the ITR tach will read about 8700 but in fact redlines at 8400 and some change. doesnt mean it wont go to 10-11x rpm's on a stock ecu.
Old Mar 11, 2005 | 07:39 PM
MOVE OVER's Avatar
Default Re: search for itr rev limiter returned nothing useful (TodaFiend)
yea, i do realize all of that, thanks for the info. i was talkin about it in neutral. it makes perfect since y it would over rev if it was in a lower gear. i guess it just doesnt really matter as long as ur real careful with it
Old Mar 11, 2005 | 11:13 PM
Azcheron's Avatar
actually fuel cut is 8600 on a stock R redline is 8400
it is even clearly shown on your tach
the red starts at exactly 8600 and that is exactly where your car with bounce off the limiter if your tach is accurate
Old Mar 12, 2005 | 09:40 AM
#1151's Avatar
Default Re: search for itr rev limiter returned nothing useful (Azcheron)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Azcheron &raquo;</TD></TR><TR><TD CLASS="quote">actually fuel cut is 8600 on a stock R redline is 8400
the red starts at exactly 8600 and that is exactly where your car with bounce off the limiter if your tach is accurate</TD></TR></TABLE> hahaha people dont listen. YOUR TACH IS NOT CORRECT. fuel cut is 8400. your tach reads 8600-8700 but in reality you are at about 8400. I dont care what YOUR tach says, redline it with a snap on timing gun...truth is right there. digital.
Old Mar 12, 2005 | 11:29 AM
Dr Pooface's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TodaFiend &raquo;</TD></TR><TR><TD CLASS="quote"> hahaha people dont listen. YOUR TACH IS NOT CORRECT. fuel cut is 8400. your tach reads 8600-8700 but in reality you are at about 8400. I dont care what YOUR tach says, redline it with a snap on timing gun...truth is right there. digital. </TD></TR></TABLE>
As an aside, on a road trip to Spokane two years ago I tested out my tach on a long straight stretch of highway, in 4'th gear. My stock tach was deadly acurate for vtec engagement, disengagement, and fuel cut.
But when drivin hard in 2'nd gear the tach would seem to read inaccurately higher.
Maybe the tach carries a bit of momentum when it is forced to spin quickly, and therefore seems to be inaccurate. Just a guess, I have no idea how the mechanics of it work.
Old Mar 12, 2005 | 02:12 PM
MOVE OVER's Avatar
Default Re: search for itr rev limiter returned nothing useful (Dr Pooface)
gotcha. well, thanks for the replies guys
Razr2
15
Jan 1, 2008 10:24 PM
accordtunerx
Jun 12, 2005 08:40 PM
petrv
Apr 25, 2005 02:24 PM
1SlowSi
Feb 25, 2004 05:59 AM
2slo4me
Jun 23, 2003 11:22 AM
