Gen5 Gauge lights/bulbs
Old Mar 10, 2005 | 05:06 PM
z168's Avatar
Default Gen5 Gauge lights/bulbs
Does someone know the exact part# or code of the bulbs for the gauges :
1. Turn
2. E-brake
3. high beam
4. cruise control
5. etc
the gauges i have are all in white. the prev owner removed the red, green and blue rubber covers on the bulbs.
any info where i can get them highly appreciated
Old Mar 10, 2005 | 05:09 PM
hotaccord243's Avatar
Default Re: Gen5 Gauge lights/bulbs (z168)
you know i dont' know the part # or anything but go to either autozone, checker, or carquest and ask them, they will probably know
Old Mar 10, 2005 | 06:04 PM
clemsoncb7's Avatar
Default Re: Gen5 Gauge lights/bulbs (hotaccord243)
junkyard will be a good source... locate a 5th gen cluster and take the bulbs you need. good luck!
Old Mar 10, 2005 | 10:01 PM
z168's Avatar
Default Re: Gen5 Gauge lights/bulbs (maxvtec7500)
well I went to Kragen earlier this evening. they dont know the exact bulbs. i have to bring the exact bulbs in.
i was hoping to remove the gauges with the bulbs already in hand
the junkyards from where I am are kinda far. too much hassle for a handful of small bulbs
Old Mar 10, 2005 | 10:06 PM
-Bionic-'s Avatar
Former Sponsor
Just remove the cluster. A few screws and you are done. In reference to the 6th gen cluster, there are some wedge bulbs and some a bunch of small bulbs that are the same as the one for the clock. I believe radio shack carries them.
I would think that the 6th gen cluster and the 5th gen cluster would be similar when it comes to the bulbs used.
Old Mar 11, 2005 | 01:12 AM
The_Todd's Avatar
Farts in the shower
I believe they are instrument bulbs (74 or 79) and bulb 194...if you're wanting to change the color of your cluster kragens won't carry anything but oem; try online.
Old Mar 11, 2005 | 12:11 PM
z168's Avatar
Default Re: Gen5 Gauge lights/bulbs (.ken)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .ken &raquo;</TD></TR><TR><TD CLASS="quote">I believe they are instrument bulbs (74 or 79) and bulb 194...if you're wanting to change the color of your cluster kragens won't carry anything but oem; try online.</TD></TR></TABLE>
the prev owner of the car changed everthing to white. high beam, turn, e-brake, cc, everything. i just want to switch them back to stock colors
Old Mar 11, 2005 | 01:13 PM
s.cali alan's Avatar
just use some plastic colored transparent film. and match the colors back. it would be like how it is normally. the guy prollie just took out the whole sheet.
ebrake: red
cruisecontrol:green
high beam: blue
abs: red
turn: green
zer0Limitz
11
Sep 13, 2019 06:42 PM
aznboistitch
Sep 1, 2006 01:34 AM
idolized1
Jan 4, 2005 10:39 AM
rasta420
Nov 21, 2002 09:56 AM
CivicDXR
15
Oct 16, 2002 01:30 AM
