How do I pull the diff?
Old Mar 10, 2005 | 04:43 PM
Atheist's Avatar
Default How do I pull the diff?
I've got my gearbox down and the case off and am looking at
I am trying to get the fricken diff out. How do I do it? This is from a b16 honda tranny.
Old Mar 10, 2005 | 04:57 PM
IN VTEC's Avatar
Default Re: How do I pull the diff? (Atheist)
PUll the gear sets/shift forks and then you can remove hte diff.
Old Mar 10, 2005 | 05:17 PM
Atheist's Avatar
Default Re: How do I pull the diff? (IN VTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IN VTEC &raquo;</TD></TR><TR><TD CLASS="quote">PUll the gear sets/shift forks and then you can remove hte diff.</TD></TR></TABLE>
I have to pull the forks?
rjay8604's Avatar
Once the other **** is out it should just pull out by hand.
Old Mar 10, 2005 | 06:33 PM
Atheist's Avatar
So what do I need to pull? Just the shafts and then the final drive will be sitting there, or do i need to unboplt that then also or what?
Old Mar 10, 2005 | 08:52 PM
sporkcrx's Avatar
Default Re: (Atheist)
You need to pull out the whole gear assembly.
Old Mar 11, 2005 | 05:12 AM
Atheist's Avatar
Default Re: (sporkcrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sporkcrx &raquo;</TD></TR><TR><TD CLASS="quote">You need to pull out the whole gear assembly.</TD></TR></TABLE>
Any kind of guide on getting the shafts from the case once I have the forks pulled? I'm not sure how they'll be secured.
Old Mar 11, 2005 | 08:45 AM
IN VTEC's Avatar
Just remove the forward and reverse gear change holders, and pull the gearsets and shift forks straight up.
The gearsets and shift forks come up as one assembly, but after that, the forks can fall wherever they want.
Old Mar 11, 2005 | 11:49 AM
h22 civic's Avatar
Default Re: (IN VTEC)
if my memory serves me correct didnt in vtec do a very good write up on this subject
Old Mar 11, 2005 | 01:54 PM
village_idiot's Avatar
That was mega easy! BUT, now I don't know how to break it down any farther!
Whats my next step?
^^Atheist btw
Old Mar 11, 2005 | 01:58 PM
Since i was having a speedo problem, can anyone tell me from looking at it, doesn't it seem that I am missing the speedo drive gear completely?
Old Mar 11, 2005 | 02:29 PM
rjay8604's Avatar
Default Re: (village_idiot)
You have to remove those bolts, the should be left hand threads. then your done.
Old Mar 11, 2005 | 02:56 PM
What about the bearing, how do I get that sucka off
Old Mar 11, 2005 | 03:24 PM
Question,
Can I use a stock speedo drive gear from a b16 with any differential?
Old Mar 11, 2005 | 04:48 PM
Runnerdown's Avatar
The speedo drive gear is missing. The bearing should be removed with a puller however some can be removed with screwdrivers IF your careful. What I would like to know is where the drive gear is
edit- i'm 99% sure the drive gears are all the same. Is it a cable or hydro b16 tranny?
USDM-EK4*
Jun 5, 2007 09:33 PM
bluesaint
Aug 9, 2006 06:07 AM
Thizzed Out
Apr 11, 2006 04:41 AM
gray_civic_coupe
Jan 8, 2006 12:49 PM
C-Zero
28
Jul 27, 2004 10:35 AM
