Piston job???
Was just wondering how much a machine shop would usually charge to replace the pistons/rings/wrist pins, and maybe bore the chambers alittle. I'm purchasing some CTR pistons and would like to know a figure. Thanks H-T
Do you want them to "bore the cylinders a little" or bore them to the correct diameter for the pistons you want to install? Also is the motor pulled or still in the car?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jlacoy82 »</TD></TR><TR><TD CLASS="quote">Do you want them to "bore the cylinders a little" or bore them to the correct diameter for the pistons you want to install? Also is the motor pulled or still in the car?</TD></TR></TABLE>
LOL, you know what I mean, YES bore them to correct diameter. No the motor is still in her.?
.adam.
Nov 21, 2007 02:39 PM
