GSR crank in my b16a. Benifits?
I dont know if anyone makes custom pistons fro this setup. But i know they do for 84.5 and 89mm cranks. I dont know if it would be worth it.
With out custom pistons, you'll probably put a piston through the head. The b16 deck height is not the same as the b16b. If you really want to make your 1.6 into a 1.8 then use the tech43 stroker kit that allows you to use the Ls's 89mm stroke and rods, otherwise its a bad idea...a very bad one lol.
DYNO-PRO
From: SoCal I.E 909, CA, where we innovate not immitate
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drchulo »</TD></TR><TR><TD CLASS="quote">With out custom pistons, you'll probably put a piston through the head. The b16 deck height is not the same as the b16b. If you really want to make your 1.6 into a 1.8 then use the tech43 stroker kit that allows you to use the Ls's 89mm stroke and rods, otherwise its a bad idea...a very bad one lol.</TD></TR></TABLE>
b16nonoy
May 12, 2006 05:20 AM
