why have stand alone fuel management?
Old Mar 10, 2005 | 11:06 AM
idle's Avatar
Default why have stand alone fuel management?
ok, first off, i'm a noob jsut trying to learn as much as i can!
i've heard of people using standalone fuel management systems and was jsut wondering what this incorporates and why its used. also is it the same thing as a Piggyback Engine Management System?
cheeroid
Old Mar 10, 2005 | 11:15 AM
tgreaves's Avatar
Default Re: why have stand alone fuel management? (idle)
A standalone is where you replace/modify the stock ecu.. A piggyback system is where you modify the signals going into/out of the stock ecu to adjust things..
When you modify your engine then you need to retune it since the orginal tuning is no longer valid.. And you have to have some way to modify the stock tuning, either a standalone or piggyback or something like that..
Old Mar 10, 2005 | 11:20 AM
idle's Avatar
Default Re: why have stand alone fuel management? (tgreaves)
cheers man
am i right that tuning is done directly into the ecu or whatever thru a laptop or pc? or do u have to burn rom chips or something?
Old Mar 10, 2005 | 11:21 AM
tgreaves's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by idle &raquo;</TD></TR><TR><TD CLASS="quote">cheers man
am i right that tuning is done directly into the ecu or whatever thru a laptop or pc? or do u have to burn rom chips or something?</TD></TR></TABLE>
Depends on what ecu your using.. If your using hondata or uberdata then you need to burn chips..
Im using the AEM EMS and its all real time live tuning with no chip burning needed..
detour94civic
Dec 27, 2010 02:55 PM
si 2
Sep 1, 2007 06:53 AM
busakiller
Aug 8, 2004 08:02 PM
Stock@$$GSR
Dec 24, 2003 10:35 PM
94tegGSR_TypeR
Aug 20, 2001 08:30 AM
