omg. haha. check this out. head gasket change :p
Old Mar 10, 2005 | 10:59 AM
saltyblue's Avatar
Default omg. haha. check this out. head gasket change :p
ok...i assume its not normal to have water in there like that?
also, i'm not 100% knowledgeable...but there is a small area around the entire set of pistons. it has collant in it. i assume that has to be there but not actualy on the pistons themselves?
we are changing the head gasket btw ::D
Old Mar 10, 2005 | 11:00 AM
pwrofdrm's Avatar
Default Re: omg. haha. check this out. head gasket change :p (saltyblue)
Just means your headgasket was blown..which you already knew. Just suck it out with a shop vac
Old Mar 10, 2005 | 11:02 AM
Ls_V_TurboSi's Avatar
Default Re: omg. haha. check this out. head gasket change :p (lax1185)
you should have puled the whole head of with the intake mani..
saltyblue's Avatar
yea we got the water off the pistons. but there is like a thin empty area between the outter shell and the inner section holding the pistons. this area has coolant in it still. is that supposed to be there? to keep the pistons cooled maybe?
also, is there a screw or anything you can take oput to drain the coolant out of that section?
Old Mar 10, 2005 | 11:04 AM
hahagasdcrx's Avatar
Yeah the coolant is suppose to surround the pistons. Its an open deck block.
EP3_05's Avatar
Yes that little area around the pistons is the water jacket. It is supposed to have coolant flowing through it to cool the pistons and sleeves. There should be a big bolt on the front of the block. Remove that and the coolant should drain right out.
Old Mar 10, 2005 | 11:07 AM
saltyblue's Avatar
Default Re: omg. haha. check this out. head gasket change :p (91civic)
LOL thanks alot guys. we thought that big one but then thought it couldnt be so big. you guys are awesome
*goes back out*
Old Mar 10, 2005 | 11:08 AM
ssl2k's Avatar
You didn't have that much water in the car when it was running, when you took the head off it all leaked in there and ****. Yeah your headgakset was blown, but it wasn't that bad. if it was, you'd have a little bit more problems than a blown headgasket.
You should take the time to do a MPFI swap right now too.
btw, i like the red block.
sporkcrx's Avatar
You should of drained the coolant out of the block with the plug in the block, before removing the head. That way it wouldn't of all leaked in there when you loosen up the head.
EP3_05's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by saltyblue &raquo;</TD></TR><TR><TD CLASS="quote">LOL thanks alot guys. we thought that big one but then thought it couldnt be so big. you guys are awesome
*goes back out*</TD></TR></TABLE>
One more thing prepare for that bolt to be on there really tight. I had a pita time getting mine out of my b16a.
Old Mar 10, 2005 | 11:09 AM
saltyblue's Avatar
Default Re: (ssl2k)
we've never had the car running. ever. we bought it like this. thought it was the main relay. replaced thatg. didnt work. called over someone who knew something and he said head gasket was gone
Old Mar 10, 2005 | 11:12 AM
saltyblue's Avatar
Default Re: (saltyblue)
sss2k - You should take the time to do a MPFI swap right now too.
how?
Old Mar 10, 2005 | 11:21 AM
CRX_1.8T's Avatar
Check in this FAQ thread. I browsed through it and saw several MPFI conversion links. Just gotta read through it, it's a lot of material.
https://honda-tech.com/zero...age=1
MalcolmV8
May 18, 2012 03:19 PM
d0ugch0i
Nov 15, 2007 06:18 PM
96SR-V
May 1, 2003 08:02 PM
GummiBeer
17
Mar 9, 2003 09:30 PM
TRuST
Aug 29, 2002 06:32 PM
