Buddy Club Cams
I am thinking about droping these into my b16 but have a few questions. I know I will probly have to upgrade the valve springs, but will the stock retainers do? How much more are you able to rev with these cams to get good power?
I am pretty sure for anything but Stage 1....you have to upgrade...
-springs
-retainers
-valves
If you are gonna go Buddy Club Stage 3...then you should be able to afford to upgrade all at the same time...and might as well get your head done at the same time....would make cignificant gains i think
-springs
-retainers
-valves
https://honda-tech.com/zerothread?id=1050078 check this thread out...hopefully it'll be of some help to you.
The buddy club spec 3 are a stage 1 cam....they dont have to much lift, just more duration. Im pretty sure with type r valve springs it should be good but I have b16 valve train. I think the retainers are the same as the type r but the springs change.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sheepeg3 »</TD></TR><TR><TD CLASS="quote">i know people that run stock valvetrain on bc3s. but only thing that worries me is if u over rev past 9 k or something..
Is that on b16 valve train?
in that thread Rocket mentioned he wouldn't reccommend running on stock VT. i don't know Rocket personally but from reading all his posts he knows his ****...... i would at least upgrade to either itr or omni. but this is just my 2cents bro.......good luck with your decision.
yes its b16 valvetrain. Honestly I dont recommend it. Cause dropping a valve can ruin everything. Just be safe and get springs and retainers. I run supertech and its great, contact earl if u're interested.
codeh22a4
Mar 30, 2005 04:12 AM
Sideshow9090
Feb 3, 2005 10:00 AM
