HELP WITH D15B SWAP
Old Mar 10, 2005 | 08:56 AM
STR931's Avatar
Default HELP WITH D15B SWAP
I have an 89 DX and brought a 92 D15B motor to put in it. It was supposed to come with a tranny, but the guy sold that separate. So I brought a 88 Si tranny cuz I was told it would work. Now the guy who sold it to said it wouldn't. I just need to know is it possible or not. I have already started my swap and have gone to far to turn back now.
Old Mar 10, 2005 | 08:58 AM
EP3_05's Avatar
Default Re: HELP WITH D15B SWAP (STR931)
It will work as long as you use a clutch (and i believe you need the flywheel...someone correct me if i am wrong) from an 88 civic/crx
Old Mar 10, 2005 | 09:07 AM
STR931's Avatar
Default Re: HELP WITH D15B SWAP (91civic)
That is what a few people told me. So I think youre right. I was also told all you need to do is switch the input shafts from the 88 tranny to the D15B. I never done anything like that. Any thoughts?
Old Mar 10, 2005 | 09:08 AM
EP3_05's Avatar
No there is no need to switch input shafts. The only mod you need to make is the clutch and flywheel
Aragorn's Avatar
Yea, actually, you could NOT use the '92 tranny. It's the one that won't fit. The '88 will fit. Here's a page that has all the size/spline conut info you'll need:
http://thenew.gamesbbs.com/~dmoore/tranny.htm
Unfortunately, '88 is an odd ball year and is smaller in diameter and uses a different spline count than other years, so you pretty much need clutch, Pressure plate, and flywheel for the '88.
Old Mar 10, 2005 | 09:12 AM
STR931's Avatar
Default Re: HELP WITH D15B SWAP (Aragorn)
I just called a friend who is doing the swap with me. He said the only differnce is the bearings. And all we need to do is change them.
Old Mar 10, 2005 | 09:23 AM
Aragorn's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by STR931 &raquo;</TD></TR><TR><TD CLASS="quote">I just called a friend who is doing the swap with me. He said the only differnce is the bearings. And all we need to do is change them.</TD></TR></TABLE>
The only difference between what is bearings?
Old Mar 10, 2005 | 09:27 AM
STR931's Avatar
He said if we switch the bearing on the 88 tranny and everything else will fit fine.
Old Mar 10, 2005 | 09:31 AM
Aragorn's Avatar
Default Re: (STR931)
It has nothing to do with bearings. The tranny physically fits, its just that an '88 uses a different spline count on the input shaft that later trannies and it also uses a smaller clutch/PP/flywheel that later cars.... check the link and good luck if you guys aren't going to listen.....
Old Mar 10, 2005 | 09:32 AM
EP3_05's Avatar
The fitment problem has nothing to do with the bearings. The input shaft spline count is different between the 88 and 89-90-91 transmissions. Plus the 88 has a smaller clutch surface area hence you need a different flywheel. Just get the 88 clutch and flywheel and use the 88 trans. Or you could get an 89-91 transmission and use the clutch that is on the engine.
Old Mar 10, 2005 | 09:34 AM
STR931's Avatar
Thanks. I think I'll do that. Do you know any good places to order the fly wheel and clutch?
Old Mar 10, 2005 | 09:37 AM
Aragorn's Avatar
Clutch City Online on E-bay....
http://stores.ebay.com/id=32441765&ssPageName=L2
jdmb20boi
11
Jun 12, 2008 09:27 PM
Slowass2dr
May 2, 2007 05:58 PM
cpizzy
Dec 16, 2003 08:17 AM
94sisol
Sep 28, 2003 06:13 PM
Kilohead36
Mar 22, 2003 06:34 AM
