PLEASE HELP FAST!!!
Old Mar 10, 2005 | 08:26 AM
jdmboy1825's Avatar
Default PLEASE HELP FAST!!!
i have a 99 civic si with a 98 integra type r engine. i have a engine coolant temp code and the sensor has the correct resistance, the sensor has power in and out, and the computer has a signal in and out. i need to have it fixed by saturday so i can sell the thing. please help.
Old Mar 10, 2005 | 11:56 AM
Perfectionist's Avatar
Default Re: PLEASE HELP FAST!!! (jdmboy1825)
Are you testing the correct sensor? If it's a code for the TW sensor, it's not the one mounted on the radiator. The TW sensor was under the distrubutor area on older gen's, not sure about yours.
The sensor is a variable resistor. The value changes with temperature. They can develope dead spots as they go from cold to hot resistance values. You would really have to watch it patiently throughout it's operating range to see it. Easiest to just swap it out with a new/used one if all the other trouble shooting methods check out ok.
Old Mar 10, 2005 | 12:01 PM
PrettyLude's Avatar
first off try and replace it with another one, its not that expensive like 5 bucks or so and go from there
Old Mar 10, 2005 | 12:02 PM
jdmboy1825's Avatar
yes, its the correct sensor
knboard
Honda CR-V & Element
May 12, 2018 10:19 PM
99d-series
May 1, 2009 08:56 AM
jpangeles
Sep 12, 2004 05:23 PM
pennies_hatchie
14
Oct 31, 2002 08:49 AM
