will skunk 2 camber kit work on 90 crx si
Old Mar 10, 2005 | 07:30 AM
sullenht's Avatar
Default will skunk 2 camber kit work on 90 crx si
as the topic says i have searched this and came up with nothing thanks for the help.
and if so what year and model number works thanks.
Old Mar 10, 2005 | 08:10 AM
sullenht's Avatar
Default Re: will skunk 2 camber kit work on 90 crx si (sullenht)
anyone the reason being is i have to replace the balljoint up top and the car is lowerd 1.25"
Old Mar 10, 2005 | 08:22 AM
Autoworks's Avatar
I am unsure about the Skunk, but I know for a fact the Specialty Products adj. ball joint will work
Old Mar 10, 2005 | 08:26 AM
sullenht's Avatar
Default Re: will skunk 2 camber kit work on 90 crx si (Autoworks)
do you know the cost and where to get and can i just replace the ball joint in my 90 crx si i have heard that you have to replace the whole a arm
Old Mar 10, 2005 | 08:29 AM
Autoworks's Avatar
No you don't replace the entire arm, only the ball joint with the Spec. Products. The part # is 67125, I sell them here for $135 each, but they may be found online somewhere probably a bit cheaper, they are great products.
Old Mar 10, 2005 | 08:34 AM
sullenht's Avatar
cool thanks for the help
Old Mar 10, 2005 | 09:12 AM
Tyson's Avatar
no, skunk2 doesnt off an upper adjustable a arm for the CRX.
one of the problems is that there is not enough inner fender clearance for their method of adjustment.
vision, a japanese company, does offer a similar arm as skunk2's for the crx however. theyre pretty expensive, like $560.
Wes V has gone ahead and fabricated his own arms that work for the CRX that he made from EG skunk2 arms.
Old Mar 10, 2005 | 10:41 AM
sullenht's Avatar
Default Re: will skunk 2 camber kit work on 90 crx si (Tyson)
I think i seen that thread I think i am just going to go with the adjustable ball joints
dc2ls-vtec
Suspension & Brakes
Oct 20, 2009 02:32 PM
vitrox
Jul 13, 2004 04:37 PM
iNetForce
Apr 1, 2004 07:15 AM
-16V-
Mar 18, 2004 12:55 PM
