Remove Oil Stains from Concrete Driveway.
Old Mar 10, 2005 | 07:28 AM
92 EH2's Avatar
Default Remove Oil Stains from Concrete Driveway.
I searched, and i saw some good ideas, but they are all from last year, anyone have any suggestions? last night my friends car leaked, we thought we fixed it but we didnt so theres drips and drops all the way down my parents new drive way, i need help that will get it up. TIA.
Old Mar 10, 2005 | 07:49 AM
haccord2.2's Avatar
Default Re: Remove Oil Stains from Concrete Driveway. (92 Hatchie)
Well the thing I have found to work the best is spray on brake/parts cleaner. Spray it on the spot and then us a old stiff bristle brush and brush it a little with it still wet with brake cleaner, and then spray the spot again and that should work pretty well. Just do one spot at a time and it should fix your problem. It saves my drive way all the time when people come over with leaks and leave spots. Well hope this helps, good luck.
Old Mar 10, 2005 | 07:51 AM
getnasty's Avatar
Default Re: Remove Oil Stains from Concrete Driveway. (haccord2.2)
I have always used kitty litter and dirt.
Old Mar 10, 2005 | 07:53 AM
92 EH2's Avatar
Default Re: Remove Oil Stains from Concrete Driveway. (bottle fed)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by haccord2.2 &raquo;</TD></TR><TR><TD CLASS="quote">Well the thing I have found to work the best is spray on brake/parts cleaner. Spray it on the spot and then us a old stiff bristle brush and brush it a little with it still wet with brake cleaner, and then spray the spot again and that should work pretty well. Just do one spot at a time and it should fix your problem. It saves my drive way all the time when people come over with leaks and leave spots. Well hope this helps, good luck. </TD></TR></TABLE>
thanks i tried simple green, ill try brake cleaner after school.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bottle fed &raquo;</TD></TR><TR><TD CLASS="quote">I have always used kitty litter and dirt.</TD></TR></TABLE>
tried kitty litter, it didnt help much.
Old Mar 10, 2005 | 07:55 AM
flood's Avatar
I am going to be looking into this as well as my driveway has spots. Im sure Homedepot has some solutions.
I was thinking heavy duty engine degreaser and a firm bristle scrub brush/ broom. Then hose off.
Old Mar 10, 2005 | 07:56 AM
Luserkid's Avatar
Default Re: Remove Oil Stains from Concrete Driveway. (flood)
Fire?
Old Mar 10, 2005 | 07:58 AM
92 EH2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by flood &raquo;</TD></TR><TR><TD CLASS="quote">I am going to be looking into this as well as my driveway has spots. Im sure Homedepot has some solutions.
I was thinking heavy duty engine degreaser and a firm bristle scrub brush/ broom. Then hose off. </TD></TR></TABLE>
yeah i used simple green, it didnt do much, im thinking of brake cleaner and a pressure washer
Old Mar 10, 2005 | 08:17 AM
b18bcivic's Avatar
Muriatic acid
patastinky's Avatar
Kiddy play-pen sand? You know that soft sand that you can get at home deopt or lowes to put on the ground or in a sand pit for kids. THat works for me .. then i was it away
Old Mar 10, 2005 | 08:30 AM
blkgsr03's Avatar
Default Re: Remove Oil Stains from Concrete Driveway. (patastinky)
try simple green. worked for me
Old Mar 10, 2005 | 08:31 AM
cxSHOE's Avatar
use brake cleaner and watch it disappear..
Old Mar 10, 2005 | 10:47 AM
Ls_V_TurboSi's Avatar
Default Re: Remove Oil Stains from Concrete Driveway. (cxSHOE)
carb cleaner always works for me
Old Mar 10, 2005 | 01:44 PM
92 EH2's Avatar
Default Re: Remove Oil Stains from Concrete Driveway. (Ls_V_TurboSi)
aight, thanks guys.
Old Mar 10, 2005 | 02:10 PM
fishnfst's Avatar
I second b18b for muriatic acid... Will clean anything even your skin off you hands.....
Old Mar 10, 2005 | 03:00 PM
94eg!'s Avatar
#1 Super Guy
Loved
Default Re: (fishnfst)
Kitty litter only works if you just spilled it. If you already have stains, litter only soaks up wet spots...
Brake cleaner works wonders. I've used orange blast and a wire brush, and i actually scrubed the outtermost layer of concrete off...
Old Mar 10, 2005 | 04:07 PM
m3dia_lab's Avatar
Default Re: Remove Oil Stains from Concrete Driveway. (b18bcivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18bcivic &raquo;</TD></TR><TR><TD CLASS="quote">Muriatic acid</TD></TR></TABLE>
or pressure washer if you have one...
Old Mar 10, 2005 | 08:42 PM
92 EH2's Avatar
Default Re: Remove Oil Stains from Concrete Driveway. (m3dia_lab)
my friend has a power washer, im gonna try that alone, if not, i gave the bunch of suggestions to my father, im not doing **** with out his approval, hes already pissed enough. thanks for all the help guys.
Old Mar 10, 2005 | 09:51 PM
INVALID's Avatar
From: Why so you can pretend like youre interested, FL/OK
Used it on the garage floors and concrete outside before we tiled it. It just takes TIME. No comment on the kitty litter, okay I will.. it's just like spilling paint on the carpet and just throwing a newspaper over it. It's not going to do anything.
Old Mar 10, 2005 | 10:54 PM
Motorhead
Guest
Posts: n/a
Throw some acitone on it & scrub, then brake cleaner, then simple green. If it's still there after that your screwed.
Old Mar 11, 2005 | 01:30 AM
Videodrone's Avatar
Default Re: Remove Oil Stains from Concrete Driveway. (Luserkid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid &raquo;</TD></TR><TR><TD CLASS="quote">Fire? </TD></TR></TABLE>
I'm gonna say yes
Old Mar 11, 2005 | 03:16 AM
flamega's Avatar
Default Re: Remove Oil Stains from Concrete Driveway. (Videodrone)
hey you guys are not going to believe me but...coca cola. i learned this from my grandfather, so you know its got to be right. old people know best.
Old Mar 11, 2005 | 07:15 AM
94eg!'s Avatar
#1 Super Guy
Loved
Default Re: Remove Oil Stains from Concrete Driveway. (flamega)
I once spilled fresh royal purple on my drive way. Nothing was getting that stain out. A few months later, and its almost invisible...
Old Mar 11, 2005 | 08:09 AM
ralphie14's Avatar
Default Re: Remove Oil Stains from Concrete Driveway. (INVALID)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by INVALID &raquo;</TD></TR><TR><TD CLASS="quote">
Used it on the garage floors and concrete outside before we tiled it. It just takes TIME. No comment on the kitty litter, okay I will.. it's just like spilling paint on the carpet and just throwing a newspaper over it. It's not going to do anything. </TD></TR></TABLE>
Yeah I think that is the same acid that they give you when you prep your garage floor when you apply that epoxy garage floor paint It was sweet your pour on the acid/water solution and then watch your whole floor bubble as the acid ate all the **** away. Garage floor looks nice plus oil and stuff will not stain anymore.
Old Mar 11, 2005 | 08:26 AM
dzminiz's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by flamega &raquo;</TD></TR><TR><TD CLASS="quote">hey you guys are not going to believe me but...coca cola. i learned this from my grandfather, so you know its got to be right. old people know best. </TD></TR></TABLE>
jrockets
Nov 27, 2006 10:59 PM
hennessy
Jun 26, 2006 12:51 AM
BLUE EH3
May 11, 2005 11:12 AM
trev4
Honda Motorcycles
Aug 11, 2004 03:36 AM
integranator
Apr 25, 2003 04:27 PM
