NEED HELP sohc clutch
Old Mar 9, 2005 | 09:46 PM
Honda-Hooligan's Avatar
Default NEED HELP sohc clutch
well i just got done my z6 swap now i think i messed up on the clutch part.see i have a 98ex tranny on my z6 engine and i have z6 clutch and flywheel now the clutch does not feel like its working right.
my question is if i messed up on the clutch tranny combo i mean do i have to have clutch and fly wheel for 98 ex tranny or wut.
i know i dont make to much sense but i cant think or do anything else.
I HAVE SEARCHED
thanx
Old Mar 9, 2005 | 09:48 PM
BauleyCivic's Avatar
Risky Business
Default Re: NEED HELP sohc clutch (Honda-Hooligan)
Should work fine...all of the 92-00 transmission/clutch stuff is interchangable.
Old Mar 9, 2005 | 09:50 PM
Kendall's Avatar
Check the fluid and bleed the line before you do anything else.
Old Mar 10, 2005 | 08:13 AM
civic-4-ges's Avatar
Default Re: (Kendall)
Did you clean the flywheel off prior to installing it???
Old Mar 10, 2005 | 08:46 AM
delslo93's Avatar
Default Re: (civic-4-ges)
yeah make sure the flywheel doesnt have any oil or anything on it.
Old Mar 10, 2005 | 08:49 AM
i put a brand new flywheel on before reassambly. now heres another thing my car was auto and i did the manual convertion.
Old Mar 10, 2005 | 08:51 AM
Was it a brand new clutch, did you bleed the clutch lines?
Does it slip, engage early, late???
snatch's Avatar
What do you mean by "not working right".
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic-4-ges &raquo;</TD></TR><TR><TD CLASS="quote">Does it slip, engage early, late???
Yeah, what this guy said.
Old Mar 10, 2005 | 07:51 PM
Default Re: NEED HELP sohc clutch (******)
i bled the lines clutch is brand new and just picture this
divide the pedal travel on 4ths mine only has laberage 1/4 means that only comes out 1/4 maybe little more and feels really soft on the pedal but it engages pretty hard
i have a act stage 3
EDWINV00SI
24
Oct 13, 2011 06:08 PM
allmotor99lude
Jul 7, 2005 08:01 PM
rasinhell
Jan 29, 2005 04:58 PM
