Can you use H22 shifter box and cables for a K20 swap??
Old Mar 9, 2005 | 08:32 PM
Maddox's Avatar
Default Can you use H22 shifter box and cables for a K20 swap??
Does anyone know if you can use H22 parts on a K20 swap?
I have the cables and shifter box from a H22 EG swap and I was wondering if I could use those for a K20 swap.. Any info would help. Thanks Guys.....
Old Mar 9, 2005 | 08:40 PM
Goatsterrman's Avatar
Default Re: Can you use H22 shifter box and cables for a K20 swap?? (AllMotorCRX161)
You can modify an Accord shifter box to work, but the cables won't work.
Old Mar 15, 2005 | 07:58 PM
fabworxs's Avatar
Default Re: Can you use H22 shifter box and cables for a K20 swap?? (Goatsterrman)
DOes NOT work. Before breaking down and buying new linkage from the dealership I tried the plastic Accord shifter box & linkage & steal Prelude shift box & cables NIETHER WORKED. If anyone tells you other wise its probabbly a getto set-up.
Your better off getting the right parts vs. messing up a $$$$ tranny.
Old Apr 17, 2005 | 08:32 AM
hndarcrb18c1's Avatar
Default Re: Can you use H22 shifter box and cables for a K20 swap?? (fabworxs)
It does work.. you just need to shorten the up/down cable 1 inch..
DeeJHonda95
Transmission & Drivetrain
Feb 13, 2014 04:50 AM
Mfoehrkolb
Sep 29, 2010 11:50 AM
MikeW
Aug 4, 2009 04:15 PM
94lt1
Nov 23, 2007 03:25 PM
