B20 VTEC Turbo Idle Problems
Old Mar 9, 2005 | 06:01 PM
ECICivic's Avatar
Default B20 VTEC Turbo Idle Problems
I have an idle problem that no matter what i do i can't figure it out. I have put a new throttle body gasket, new IACV, checked for leaks on all vaccum lines, changed the map sensor, check coolant and can't figure it out. It idle high at 1200 and moves around a lot. When I drive it and stop it jumps to 1900 and slowly goes down to 1200 and no lower. Sometimes it gets really bad and throw a light for the IACV. Any ideas. Need help with this bad. Also tried changing out ECU's and nothing there.
Old Mar 9, 2005 | 06:32 PM
Kendall's Avatar
Test the wiring between the ECU and the IACV, it's possible that it's shorting out and not getting correct voltage.
Old Jun 27, 2005 | 09:43 AM
1slowEK's Avatar
Default Re: (Kendall)
try cleanin out the iacv... i read something somewhere about it... with some carb cleaner or some ****..
Old Jun 27, 2005 | 12:56 PM
BustedLX's Avatar
If you completely cover the TB opening does the engine die or continue to run?
Old Jun 27, 2005 | 03:18 PM
happy!'s Avatar
bump, cause same thing is happening to me.
Old Jul 10, 2005 | 10:35 AM
gsr_b20x2's Avatar
Default Re: B20 VTEC Turbo Idle Problems (ECICivic)
currently being built...Gsr-B20 Vtec / T3/T4 FULLY BUILT....this sounds scarry...anybody find the cause behind this...??? motor will be dropped once Clutch fork gets in...
Old Jul 11, 2005 | 12:12 PM
RedSilver2.2's Avatar
did you do any customer work to your intake manifold?
Old Jul 14, 2005 | 12:32 PM
gsr_b20x2's Avatar
Default Re: (RedSilver2.2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RedSilver2.2 &raquo;</TD></TR><TR><TD CLASS="quote">did you do any customer work to your intake manifold?</TD></TR></TABLE>
i didnt...stock gsr IM....
EL_LOCO
Jan 22, 2014 10:16 AM
hollywood97civic
Nov 5, 2012 12:46 PM
ECICivic
Mar 16, 2005 10:46 AM
96MidoriHatch
Oct 31, 2004 01:41 PM
Curturbo
Jul 19, 2004 07:15 PM
