Starting Problem 91 civic hatch
Old Mar 9, 2005 | 05:20 PM
needaimport's Avatar
Default Starting Problem 91 civic hatch
sometimes when i try to start the car. the electronics go on and it makes a sort of whining noise. ( like a small higher pitched.....vzzzzzzz)
and it takes like 5 minutes to finally start. wtf is wrong ?
Old Mar 9, 2005 | 05:45 PM
B16aef9's Avatar
Default Re: Starting Problem 91 civic hatch (needaimport)
Check engine light? Does it throw a code?
Mine did something similar to that pissed me off when I would have to sit there for a long time. I believe it threw a Code 16 which is something to do with Fuel. Either injector or bad ecu. I recommend checking the code to see what is wrong.
Old Mar 9, 2005 | 06:34 PM
Default Re: Starting Problem 91 civic hatch (B16aef9)
no CEL. but one time when i took a hard kind of turn it threw a cel and then it was gone...weird ?
Old Mar 9, 2005 | 07:45 PM
AzNKhMeRrAcErNzA's Avatar
can it be your Relay? My crx is having the same problems. I think its my relay, but i'm not for sure. well u should check it.
Old Mar 11, 2005 | 07:56 PM
BUMP
also it makes that vzzz sound and when you stop trying to start it, it makes a "click" sound sound.
Old Mar 11, 2005 | 08:01 PM
HatchBox's Avatar
Skoobie no more...
Default Re: (needaimport)
could be the solenoid in the starter. Its turning but its not poping out and enguaging with the flywheel.
Old Mar 11, 2005 | 09:31 PM
thanks, can anyone confirm that?
also i have no idea what/where this solinoid is.
Old Mar 12, 2005 | 07:22 AM
bump
Old Mar 12, 2005 | 09:36 PM
bump. help please
KINGVEM^^ED6
13
Apr 28, 2010 06:33 AM
BiG ChOr!Zo
Nov 3, 2009 05:43 PM
slowFTW
Oct 18, 2009 07:45 PM
Burke
May 10, 2004 09:48 AM
Burke
May 8, 2004 06:12 AM
