engine sputter
Old Mar 9, 2005 | 02:32 PM
mojo_2711's Avatar
Default engine sputter
anyone know what would be causing my b16 to be sputtering or lagging then taking off when i accelerate?
Old Mar 9, 2005 | 02:45 PM
eK9aT10pSi's Avatar
Default Re: engine sputter (mojo_2711)
care to be more specific of deatials you porlly left out ? such as setup, when i does that, hot or cold, etc ?
fyi .. in the future, DONT be so vague.
mojo_2711's Avatar
sorry it says i cant instant message. Would it just happen like that i went to get gas and it was fine but after i got the gas the **** hit the fan
Old Mar 9, 2005 | 02:48 PM
mojo_2711's Avatar
well it does it all the time. not under slow acceleration but under hard acceleration.
Old Mar 9, 2005 | 02:55 PM
SL!M's Avatar
Is your CEL coming on at all? Does you smell gas? Do you see gas on the ground? It sounds like you may have a fuel problem, I'd check into that first, then get into deeper things.
Old Mar 9, 2005 | 03:05 PM
mojo_2711's Avatar
Default Re: (SL!M)
na none of that is happening. i put injector cleaner in it this morning when i filled up but its still doing it
Old Mar 9, 2005 | 03:42 PM
eK9aT10pSi's Avatar
Default Re: (mojo_2711)
car/motor, setup ?
Old Mar 9, 2005 | 04:17 PM
HitEm'Up's Avatar
Default Re: (eK9aT10pSi)
It could be alot of things you need to tell us your setup?miles? things like that
Old Mar 11, 2005 | 08:58 AM
mojo_2711's Avatar
Default Re: (98JRSChatch)
the engine has about 50k on it. its in a 93 integra. it has a gsr ecu that has been modified. i am getting a distributer cap and rotor put on and changing plugs and plug wires so hopefullly that will work
Old Mar 11, 2005 | 09:42 AM
Ragecloak's Avatar
My car was doing that for a while too...I couldn't figure it out either, but it just eventually stopped.
bizmarts
Aug 17, 2017 12:30 PM
Si Arn
Aug 14, 2008 11:53 AM
STEV3-O
77
Aug 3, 2005 12:03 PM
Mr.SpiLLz
Apr 30, 2003 09:41 PM
Spyderwebab
Feb 13, 2003 03:34 PM
