EK JDM H22 SHIFT CABLES
Old Mar 9, 2005 | 02:31 PM
ykenomke's Avatar
Default EK JDM H22 SHIFT CABLES
I GOT A PROBLEM ON MY SHIFT CALBES
i CAN NOT CHANGE GEARS
Old Mar 9, 2005 | 03:05 PM
skunked's Avatar
Default Re: EK JDM H22 SHIFT CABLES (ykenomke)
pics no worky
Old Mar 9, 2005 | 03:35 PM
fastwanabe's Avatar
how do you know its the cables causing your problem?
Old Mar 9, 2005 | 04:07 PM
skunked's Avatar
Default Re: EK JDM H22 SHIFT CABLES (fastwanabe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fastwanabe &raquo;</TD></TR><TR><TD CLASS="quote">how do you know its the cables causing your problem?</TD></TR></TABLE>
Could be the tranny, clutch, slave cylnder....LOL who knows
Old Mar 11, 2005 | 03:26 PM
IHateJDM's Avatar
Default Re: EK JDM H22 SHIFT CABLES (skunked)
I had the same prob in my h22 del sol. My prob was because of the sharp bend the cable (forwards and backwards shifting) had to make right after it ran over the crossmember. I ran through 3 cables in 4 months. First disconnect the cable from the lever on the tranny and make sure the lever still moves. If not, you have bigger problems. If the cable won't move, it'll have to be replaced. I ended up using one of the other cables (side to side motion cable) and modifying it to fit. You need to chop a piece out of the part that connects to your shifter since the distance from where the cable connects to the shifter plate and where it connect to the shifter is longer. Just get it welded back together after taking out 2 inches or so. Then I took out the busing on the bad cable where it connects to the tranny, cut it down to fit in the other cable's end and jb welded it in (poor man's fix). Been driving for 9 months plus this way, japsticking the hell out of it with no probs. That or get a custom cable made ($$). Hope that helps.
civiceg94
Dec 28, 2007 12:46 PM
9WON4
Apr 5, 2005 08:58 AM
Drum_Guru
Dec 15, 2003 05:56 PM
shauniewalnuts
May 30, 2003 08:39 AM
mckenzie
Aug 16, 2002 10:17 AM
