tell me best technique to replacing gaskets without leaking...
Old Mar 9, 2005 | 12:57 PM
5lugcivic's Avatar
Default tell me best technique to replacing gaskets without leaking...
i changed the valve cover off and now i put on new gaskets even o-Rings... 2 spark plugs keep getting flood and leaks around the valve cover. i did this two times with different brand names of new gaskets for the B18C. still leaking on me.
how do u guys do it without leaking? i stayed at factory torque. i even added little of the gasket seals also. any simple techniques?
Old Mar 9, 2005 | 01:02 PM
SOHC4life 96's Avatar
Default Re: tell me best technique to replacing gaskets without leaking... (5lugcivic)
Use OEM gaskets or get a new valve cover. If the gaskets are perfect then its most likely a warp or deformation in the valve cover that the gasket can't seal.
Old Mar 9, 2005 | 01:42 PM
HitEm'Up's Avatar
Default Re: tell me best technique to replacing gaskets without leaking... (SOHC4life 96)
I'd agree maybe the valve cover is warped
Old Mar 9, 2005 | 01:49 PM
5lugcivic's Avatar
Default Re: tell me best technique to replacing gaskets without leaking... (98JRSChatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98JRSChatch &raquo;</TD></TR><TR><TD CLASS="quote">I'd agree maybe the valve cover is warped</TD></TR></TABLE>
that would hella SOHC...!
Old Mar 9, 2005 | 02:42 PM
eK9aT10pSi's Avatar
did you put the silicon on the corner of the humps of the cams ?
Old Mar 10, 2005 | 11:06 AM
5lugcivic's Avatar
Default Re: tell me best technique to replacing gaskets without leaking... (eK9aT10pSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eK9aT10pSi &raquo;</TD></TR><TR><TD CLASS="quote">did you put the silicon on the corner of the humps of the cams ?</TD></TR></TABLE>
no, it didnt leak on corners the whole week i drove i didnt c any oil anywhere. after that week the car lags on acceleration. i checked the plugs an was flooded with oil. now i added, thats wat its called "silicon", on the rings and didnt do the corners so now still leaking in the plugs and corners.
Old Mar 10, 2005 | 11:23 AM
Ls_V_TurboSi's Avatar
theres little rubber groments that go around the spark plug holes to stop the oil from going through... Check to see if they're still there.. For the actual gasket.. you might try honda bond
Old Mar 10, 2005 | 11:26 AM
prada_2o0o's Avatar
Default Re: tell me best technique to replacing gaskets without leaking... (Ls_V_TurboSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ls_V_TurboSi &raquo;</TD></TR><TR><TD CLASS="quote">theres little rubber groments that go around the spark plug holes to stop the oil from going through... Check to see if they're still there.. For the actual gasket.. you might try honda bond</TD></TR></TABLE>
I wouldnt use honda bond on the valve cover gasket itself... its up to you tho....
Old Mar 10, 2005 | 11:32 AM
Default Re: tell me best technique to replacing gaskets without leaking... (prada_2o0o)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by prada_2o0o &raquo;</TD></TR><TR><TD CLASS="quote">
I wouldnt use honda bond on the valve cover gasket itself... its up to you tho....</TD></TR></TABLE>
I dont because I've never had that problem.. But I'd read tons and tons of post where people recommended it...
dc5tegk20
Aug 24, 2006 12:40 AM
the_0ne
22
Mar 16, 2004 02:20 PM
HONDA-2NR
18
Mar 7, 2004 07:13 PM
02 coupe
Sep 19, 2003 10:28 PM
greddyturboGSR
Mar 24, 2003 05:19 PM
