Looked but couldnt find......
Old Mar 9, 2005 | 09:24 AM
MrPotatoeHead's Avatar
Default Looked but couldnt find......
Ok I friend of mine had a JDM D15 Vtec and he had dpfi on it. And it also had a toggle switch to engage vtec. I was wondering if its safe to run a vtec head with a dpfi set up? Im going to convert it to mpfi soon but I cant till my friend helps me. Will the dpfi give enough fuel to be safe? Thanx for the input.
Old Mar 9, 2005 | 09:27 AM
EP3_05's Avatar
Default Re: Looked but couldnt find...... (OnE sToCk CrX)
DPFI on a vtec head ....I would think 2 injectors are not going to provide enough fuel for one that was designed to run four. Especially on a vtec engine that makes around 120hp compared the the dx that makes only 92
Old Mar 9, 2005 | 09:30 AM
crxnj's Avatar
Default Re: Looked but couldnt find...... (91civic)
You can do it but disable vtec..If you hit vtec with dpfi,and dx ecu you'll run real lean and probably blow up the motor..
Old Mar 9, 2005 | 09:39 AM
Aragorn's Avatar
Default Re: Looked but couldnt find...... (Mr.speaker)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91civic &raquo;</TD></TR><TR><TD CLASS="quote">makes around 120hp compared the the dx that makes only 92 </TD></TR></TABLE>
Not like this it won't..... it's running the fuel and ignition curve that go along with the DPFI.... Hell, it's even a 1.5 liter like the stock motor.....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.speaker &raquo;</TD></TR><TR><TD CLASS="quote">You can do it but disable vtec..If you hit vtec with dpfi,and dx ecu you'll run real lean and probably blow up the motor.. </TD></TR></TABLE>
TheGaginator
Jul 1, 2011 04:58 AM
Built B16A
Dec 30, 2005 04:32 PM
theSQad
Sep 26, 2005 09:08 AM
P h i l
Jul 25, 2005 08:26 PM
MrPotatoeHead
Sep 29, 2004 04:22 AM
