non vtec to vtec
non vtec to vtec
i have a dx ... and i want to build on my non vtec block ... cant i swap on a 96+ ex head and turn that little non vtec into a dx sleeper? all i need is the ex intake manifold, intake gasket, head gasket, vtec solenoid, vtec cam, vtec wiring harness and maybe some new rods? what else would i need to make this swap happen ? thanks
Re: non vtec to vtec (thesqad127)
you need to get the entire EX head. they arent hard to find
itll cost you anywhere from 100-250. and all you have to do is hook up 3 wires.
good luck
good luck
yes you can use a VAFC with your stock ecu you should also then have it tuned with the correct fuel settings for vtec
its cheaper to buy a used vtec ecu.
Re: non vtec to vtec (Kamin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kamin »</TD></TR><TR><TD CLASS="quote">yes you can use a VAFC with your stock ecu you should also then have it tuned with the correct fuel settings for vtec
its cheaper to buy a used vtec ecu.</TD></TR></TABLE>
yeah, just get the EX ecu along with the head, itll run you something like 50 bucks
ClutchPapi
05-08-2013 04:41 PM
