Reliable High Revving CrVtec
Old Mar 8, 2005 | 06:55 PM
91DroppedHatch's Avatar
Default Reliable High Revving CrVtec
Are there any ways to make a b20b block with b16 head a high revving motor? Such as aftermarket rods, crankshaft, pistons, sleeving? Also when people mate the b16 head with the b20 block, do they get the head machined to match the size of the block?
Old Mar 8, 2005 | 08:42 PM
b18bEKcoupe's Avatar
Default Re: Reliable High Revving CrVtec (91DroppedHatch)
Basically the rotating assembly was never ment to be revved high. It has high ammouts of piston to wall friction. If you want to rev high you want forged rods and pistons. A crank may not be necessary depending on how high you want to wind it out. You will also want to have the whole rotating assembly balanced and blueprinted to help. Another concideration is the stress on the sleeves. You should look at block posting or maybe even sleeving. B20's werent designed to rev high so its going to take some work but it can be done.
Old Mar 8, 2005 | 10:13 PM
HBK GABE's Avatar
Default Re: Reliable High Revving CrVtec (rsmith2786)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rsmith2786 &raquo;</TD></TR><TR><TD CLASS="quote">If you want to rev high you want forged rods and pistons.</TD></TR></TABLE>
yup
With new bearings, forged pistons and rods, block can easily take 9grand. That is good enough for me. I asked this same quesiton everywhere as well and it is reliable. Now you still need to work on your head, don't go above 8 without a good valvetrain and cams that can make power that high. Also tune tune and tune
-I'm hungry
lukerc45
Jan 23, 2024 12:34 PM
civxracer99
Dec 1, 2007 10:18 AM
type B16
Aug 20, 2006 11:41 AM
arctic-k20
Sep 9, 2003 09:29 AM
Westrock2000
25
Jun 12, 2003 06:00 PM
