Safe Rev limit
Old Aug 24, 2007 | 11:18 AM
civxracer99's Avatar
Default Safe Rev limit
With my current setup I am running a B16 with a stock block, Wiesco Pistons, Eagle Rods and a Supertech head. The car is redlining at 9200 rpms. Is this pretty safe with a stock block or should I not run it that high? I bought the car with this setup and have been out of the scene for a while and am just trying to get some thoughts on the issue. Thanks
Old Aug 24, 2007 | 11:22 AM
nWilk666's Avatar
Default Re: Safe Rev limit (civxracer99)
if you have pistons and rods you dont have a stock block.
Old Aug 24, 2007 | 11:35 AM
Sorry, meant that i DO NOT HAVE SLEEVES. My bad..Thanks for the correction
Old Aug 24, 2007 | 01:14 PM
nWilk666's Avatar
if the head is built for it, rip on that bittt
Old Aug 24, 2007 | 05:51 PM
XSIintegra's Avatar
Default Re: Safe Rev limit (nWilk666)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nWilk666 &raquo;</TD></TR><TR><TD CLASS="quote">if the head is built for it, rip on that bittt </TD></TR></TABLE>
agreed...Valve float or failure is what will kill it before the bottom end ever comes apart. I ran my stock B16 past 9k daily. Granted..I didn't care if it blew, but it stayed together. Finally...one day, it cracked a valve retainer and dropped a valve in under easy driving.
It usually always comes down to those valves and retainers.
Old Aug 25, 2007 | 05:29 AM
Default Re: Safe Rev limit (XSIintegra)
Cool. I just wanted to see if anyone had any thoughts or bad experiences with this situation. Thanks for the replys.
Old Nov 29, 2007 | 09:56 PM
ha...tch's Avatar
if you have all that work u can run that b16 to 11k rpms all day long
Old Nov 30, 2007 | 12:38 AM
hellakapps's Avatar
Default Re: Safe Rev limit (ha...tch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ha...tch &raquo;</TD></TR><TR><TD CLASS="quote">if you have all that work u can run that b16 to 11k rpms all day long</TD></TR></TABLE>
you need more than dvs's to run up to 11,000, but 9200 is fine
Old Nov 30, 2007 | 04:50 PM
JaredKaragen's Avatar
Default Re: Safe Rev limit (hellakapps)
depending on how radical your cam is, and how much street driving the car will get , is if you really need to do the retainers.
Old Nov 30, 2007 | 10:23 PM
187Chor's Avatar
trying to figure out the same thing for my own setup (dont mean to thread jack)..
..but i got a stock ctr motor with boost and am currently only taking it to 8250..
how safe will it to be to take it to 9000?
considering its already making 291whp @ 8250 im wondering if taking it to 9k will cause the bottom or top to fail first.. ?
HELP!
Old Dec 1, 2007 | 10:18 AM
bzyq2001's Avatar
and what about 10k rpm with turbo 18psi stock slaves with blockguard and built head?
Modified by bzyq2001 at 1:38 AM 12/3/2007
sh4mr0ck
Dec 28, 2008 09:56 PM
type B16
Aug 20, 2006 11:41 AM
91DroppedHatch
Mar 8, 2005 10:13 PM
ophdehEEzY
12
Dec 30, 2003 11:37 AM
arctic-k20
Sep 9, 2003 09:29 AM
