new cams,but i got a vtec problem
ok here the deal i have a b16a GEN1.replaced the cams springs and retianers all skunk 2 and the cams are stage 1.got everthing in going and i dont know if its cause we took the vtec off and its got to refill but i have a chipped ecu and it kicks in at 4800 and if i hold it say at 5200 and it starts to cut out or sputtering,but if im on it and it seems fine. could it be a fuel problem or what.
I'm having a hard time understanding your post, but I'll try my best to help you out here. Did you check your timing after everything was reassembled? Are both cams in time with each other? Check engine light by chance? What kind of chip is in the ecu?
everything is in time and i have a spoon chipped ecu and it did fine on the stock stuff,but we change the cams springs and retainers out.we got it all back in and when i drive it its fine but when vtec kicks on and say i hold it at steady at 5000rpms it kind of misses or seems like its geting to much fuel.but if im on it ,it runs fine.
From: I told you to wait in the truck in Texas, United States
After I replaced my Lost motion assembies,my car acted
really weird the first time or two the vtec engauged..
I would guess it had lost oil from the circuit..
I figured I had screwed something up but so there after
it acted normal again..
12secLSvtec
11
May 20, 2004 12:04 PM
