How long will a water pump hold on?
Old Jan 22, 2002 | 01:29 PM
Volcom's Avatar
Default How long will a water pump hold on?
I've got a 94 RS that has a water pump that has been leaking for some time now. I didn't know enough about the integra when I bought it three years ago to have it replaced with the timing belt. I make sure that there is enough coolant in the tank every couple of days. I'm just curious how long do I have? What happens when the pump goes out? Thanks
Old Jan 22, 2002 | 01:30 PM
Duck Sauce's Avatar
Default Re: How long will a water pump hold on? (Alphanumeric)
Your engine will overheat as a result and warp the head! Get that s*it fixed now!
Old Jan 22, 2002 | 01:31 PM
Instg8er's Avatar
Default Re: How long will a water pump hold on? (www.s4-mtm.com)
Yeah - don't f- around with that - get that fixed as soon as possible! Bad things can happen....
Old Jan 22, 2002 | 01:38 PM
Volcom's Avatar
How much would a water pump install at the dealer run? Just curious? I'm guessing that the pump has been leaking for 10K and I have 125K on the car.
Old Jan 22, 2002 | 01:39 PM
junglistgsr's Avatar
it'll cost about the same as a timing belt service, might as well replace that while they have it off and you are paying the labor for it...since they have to take it off and put it back on...so look at between $400-500
turq93t
10
May 16, 2005 06:00 PM
Raskal
Jan 27, 2005 07:01 AM
pnthr30
Oct 28, 2003 08:38 AM
snoop_bealybob
Mar 26, 2003 06:04 PM
Volcom
Jan 23, 2002 10:31 AM
