How long will a water pump hold on?
Old Jan 22, 2002 | 01:26 PM
Volcom's Avatar
Default How long will a water pump hold on?
I've got a 94 RS that has a water pump that has been leaking for some time now. I didn't know enough about the integra when I bought it three years ago to have it replaced with the timing belt. I make sure that there is enough coolant in the tank every couple of days. I'm just curious how long do I have? What happens when the pump goes out? Thanks
Old Jan 22, 2002 | 01:28 PM
Duck Sauce's Avatar
Default Re: How long will a water pump hold on? (Alphanumeric)
Replace it as soon as possible. If the water pump goes out on you while you're driving, you'll know it real quickly. Watch your temp. needle bury itself in the "hot" side. Just get it fixed ASAP.
Old Jan 22, 2002 | 03:21 PM
FourDoorGSR's Avatar
Which ever shop that did you timing belt install should have automatically told you that you need to replace your water pump too. Now you're going to have to pay for nearly exactly the same labor charges again since it the water pump is nearly as involved as the timing belt.
I was a lagger and didnt change my timing belt and water pump till about 110k miles. Inspected the water pump and it was still funtional but wasnt spinning as smoothly as it should have. Oh yeah now would be a good time to replace the thermostat too. Do I hear a spoon thermostat upgrade? hehe...
Old Jan 22, 2002 | 08:50 PM
Volcom's Avatar
Default Re: How long will a water pump hold on? (FourDoorGSR)
how much for the spoon therostat? I think I need to change it also.
Old Jan 22, 2002 | 09:06 PM
strils's Avatar
i dont know how much the spoon thermostat is but i just changed mine and the stock one cost me a whopping $7.00
Old Jan 23, 2002 | 10:31 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: How long will a water pump hold on? (strils)
How exactly do you tell if the water pump is good or not? One of my friends told me that if you spin the pulley, it should stop spinning immediately. He said if it continues to spin at all it's bad. Is this true?
turq93t
10
May 16, 2005 06:00 PM
pnthr30
Oct 28, 2003 08:38 AM
snoop_bealybob
Mar 26, 2003 06:04 PM
wonny
Dec 7, 2002 05:45 AM
Volcom
Jan 22, 2002 01:39 PM
