car wont start after sitting for a week
Old Mar 8, 2005 | 04:32 PM
so simple's Avatar
Default car wont start after sitting for a week
92 prelude si,
i bought it about 1 1/2 months ago, sat in the driveway until i sell my other car and switch insurance. i usually try to start it about once a week, after sitting a while and starting car would smoke but i hear thats normal. now its been a week or so since i last started it and it wont start at all. it cranks and sounds fine cranking but nothing. windows roll up and down fine, tried to let it roll down my steep driveway and push start but nothing. thought maybe fuel wasnt getting to there so i turned key on and off several times to prime pump, nothing. what can it be? according to the gauge theres about a little more than 1/4 tank left. any ideas? may try to pour some gas in there or iso-heet. i ran out of gas in my hatch before and the gauge said there was still gas
Old Mar 8, 2005 | 08:19 PM
JDMF22B's Avatar
Default Re: car wont start after sitting for a week (so simple)
have u tried hitting the gas in what i call accessory mode (because i dont know the exact technical name for it =P, but when u turn the key, before the engine comes on, but u can use every accessory ^_^)... hit the gas a few times, try and get some fuel in there, see if that works. If it worked fine before,and its just sitting there, i cant think of wtf happened=d, especially if its turning over...
Old Mar 8, 2005 | 08:20 PM
JDMF22B's Avatar
Default Re: car wont start after sitting for a week (JDMF22B)
oh yah, have u checked the spark plugs ??
Old Mar 8, 2005 | 08:28 PM
so simple's Avatar
okay just sat there and primed the pump(turn key on off several times) and tried to pump gas pedal while in ignition mode. i kept the foot on the gas and tried to start it, sounded like it almost would come on. so i prime it a lot more and give it some more gas while i started, and it came on. so weird, so was the fuel just getting old or icy? car has been sitting but i try to start at least once a week but more like once in 1 1/2 weeks
Old Mar 8, 2005 | 10:00 PM
PrettyLude's Avatar
do you have fire and fuel?
Old Mar 9, 2005 | 04:34 AM
flyrod's Avatar
Default Re: (PrettyLude)
I'd bet water in the gas from condensation in the fuel tank. Happened to me in houston anyway...
Old Mar 9, 2005 | 06:16 AM
RemerLex11's Avatar
Default Re: (flyrod)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by flyrod &raquo;</TD></TR><TR><TD CLASS="quote">I'd bet water in the gas from condensation in the fuel tank. Happened to me in houston anyway...</TD></TR></TABLE>
never would of thought of that.......how would you fix that?
Old Mar 9, 2005 | 06:20 AM
4.6LJeepXJ's Avatar
Check for fuel and spark... fuel pressure and volume...spark at the plugs..spark at the coil (external) note:pumping the gas does not prime the fuel pump...the pump primes one time when you turn the key into the accesory stage, this aint yo daddy's 72' caddy. also check to see if you have condesnation built up under your rotor...if you have a bad gasket there and it is wet out moisture can build up and prevent the wires from gettin power.
Old Mar 9, 2005 | 08:04 AM
so simple's Avatar
the car started after priming the car several times and leaving my foot on the gas while starting. im guessing condensation in tank or something
Old Mar 9, 2005 | 08:16 AM
dmxsoulja3's Avatar
Default Re: (so simple)
fresh tank of gas with iso heet if your going to store it for long periods of time.
Old Mar 9, 2005 | 08:18 AM
so simple's Avatar
oh yeah the car started but idles around 900rpm and shakes, i kept revving for a while around 2500-3000 to think maybe warm it up or something, idle rose slightly to 1k and shaking kind of went away, the idle is too low and the cars shaking now, any ideas?
Old Mar 9, 2005 | 12:19 PM
JDMF22B's Avatar
thats prolly it just sitting there being cold for too long.... drive it around for a while, park it, come back later in the day see if it still idles weird.....
also, was the car parked outside or in a garage ?
Old Mar 9, 2005 | 05:34 PM
so simple's Avatar
car was parked in my driveway, i dont want to drive the car without insurance and i still have to install my new brake master cylinder/booster, i have no brake pressure at all
Old Mar 9, 2005 | 06:05 PM
ChrisRicketts's Avatar
yea, it's probably just a little water in the tank. i was gonna ask if you were getting any spark, but i see that you got it to start. after you killed it would it crank back up again without priming it?
vartok
Jul 22, 2011 07:18 PM
dan89crxsi
16
Sep 24, 2006 01:22 PM
odishaw
Sep 25, 2004 04:45 PM
MulletManRockStar
11
Sep 19, 2004 02:44 AM
garagespecial
Jun 25, 2002 10:00 AM
