CTR piston install questions...
Old Mar 8, 2005 | 03:44 PM
Cidone's Avatar
Default CTR piston install questions...
I have a 99 B18C-R and im getting ready to put .25 OS CTR pistons in... I was just wondering what the proper tq would be for the bolts on the main and rod bolts.. Also what should the deck height be as well... If anyone could help me out that would be awesome....
Old Mar 8, 2005 | 04:44 PM
PURPLETERROR aka BIGMATT's Avatar
Default Re: CTR piston install questions... (Cidone)
9 5 1 3 7
10 6 2 4 8
mains
first step 22 ft lbs
second step 56 ft lbs for 9, 10, 7, 8
second step 49 ft lbs for 5,1,3,6,2,4
rod bolts are 33ft lbs for b18c
rod bolts for b18c5 are to be done with a con rod stretch gague 0.13-0.15mm,
or 0.005- 0.006 in
good luck with your build, all these spec's came out of the helms's service manual
Old Mar 8, 2005 | 06:06 PM
Cidone's Avatar
Default Re: CTR piston install questions... (PURPLETERROR)
Thanks
hatchyboy89
Aug 6, 2010 08:11 AM
sikcrx80
Feb 16, 2010 08:30 PM
Wazup
Mar 31, 2005 02:58 PM
kaj
Mar 1, 2004 01:43 PM
