Vtec Help: jdm b16a2 in 92 RS
Old Mar 8, 2005 | 12:10 PM
intake's Avatar
B A N N E D
Default Vtec Help: jdm b16a2 in 92 RS
http://pg.photos.yahoo.com/ph/...hotos
Please check out the setup , i got 2 pics ,
1 of the ecu setup, u can see those 2 wires from the engine bay where the vtec was tapped..
Starting from down to up, the plugs are a-b-c rite?..
Does anyone know which PLug and pin the VTEC activation is in? i thought it was c6?
P28 ECU
Old Mar 8, 2005 | 12:30 PM
Katman's Avatar
Default Re: Vtec Help: jdm b16a2 in 92 RS (intake)
your request is a little confusing, but OBD1 ecu pinouts can be found here:
http://www.ff-squad.com/tech/w...5.jpg
Old Mar 8, 2005 | 01:09 PM
intake's Avatar
B A N N E D
Default Re: Vtec Help: jdm b16a2 in 92 RS (Katman)
I thought i ficed the problem but no luck
went to go run my car and results
cold engine- rev limit at 7.2k
no vtec
warm engine- bogged at 4.5k and 5k and rev limit at 7.2
no vtec
My ecu is a custom p28
2 step launch- hold the clutch press gas and should only go to 4.5k
redlien at 8.5 k
vtec at 5k
Im gonna try rewiring my whole vtec setup.. and if that doesnt work its got to be the vtec solenoid, thank god my brothers got a extra laying area..
Ill keep u updated..
Old Mar 8, 2005 | 01:30 PM
Katman's Avatar
redline at 7200rpm eh? that sounds like a stock P28 redline. I wonder if your ecu is really chipped or not...
are you getting any check engine lights at all? if so, what mil codes are blinking on your dash?
Old Mar 8, 2005 | 03:24 PM
intake's Avatar
B A N N E D
i finished rewiring it.. and i hit vtec
warm/cold engine- VTEC worked.. reset ecu after working on her and no check engine light..
warmer engine around the half way point area- wouldnt let me go passed 4.5k
I remember the first time i tried fixing her i put in a 1.6 fuel filter from my bros 88 hb with d16z6.. Im gionna put the 1.8 LS one back in.. * if i makes a difference???? *
i checked the wiries and i dont have a Knock sensor wire, ill try that 2.. thanks katman for the diagram.. it really helped..
Anyone know where my knock sensor is? jdm b16a2
ill try those 2 things, but if no luck ill try swapping to jdm 00 Itr injectors, just in case mine are fucked.
at least i know my VTEC solenoid isnt fucked i guess..
Old Mar 9, 2005 | 07:27 AM
Katman's Avatar
you're welcome
The fuel filter won't make any noticeable difference, if you're using brand new/clean units.
The knock sensor on all DOHC VTEC engines can be found here:
(its a single wire sensor btw)
what injectors are you using?
Old Mar 9, 2005 | 07:39 AM
intake's Avatar
B A N N E D
I got her working yesterday..
Heres the issue though
When Cold- 4.5k redline no vtec
warm But not touching the line- 7.2k redline No vtec
Passed the Line- 8.5k Redline YES VTEC
this thing is really wierding me out
Ill wire the Knock sensor today when i do my suspension..
for some reason when im " Passed the line " it will bogg at 4.5 then just jump to VTEC all the way to 8.5.. GRR
Old Mar 9, 2005 | 07:46 AM
Katman's Avatar
If you didn't know, your engine has to be running at normal tempertures in order for VTEC to kick on. By default, the ecu has this cold start/safe mode, and if it detects the the car isn't warmed up yet....VTEC doesn't kick on and there's an early redline of 7500rpm. Once warmed up, VTEC kicks on and your redline is where it should be.
Your car bogs when VTEC kicks on, eh? Does it kick on before 5000rpm? if so, that's your problem...its kicking on too early and thats the result, boggyness. If you raise VTEC to 5500rpm you'll match the factory VTEC crossover point that a B16A/P30 ecu is set to.
Old Mar 9, 2005 | 07:52 AM
intake's Avatar
B A N N E D
Wise one * bows to u * lol
thanks.. really appreciate it..
well maybe i dont have to wire my knock sensor? or should i still?
yeah my Vtec comes on around 4.8-5k
For some reason even when im driving around town at nite.. it takes my CAR A long as time to warm up passed the line, Sometimes it wouldnt even pass the line.. Scares me.. But i always check my fluids and its always good..
should i check the connection on my jdm gauge cluster?
Old Mar 9, 2005 | 07:59 AM
mmuller's Avatar
Mad Scientist
you dont need to wire a knock sensor with a p28
Old Mar 9, 2005 | 08:05 AM
Katman's Avatar
Default Re: Vtec Help: jdm b16a2 in 92 RS (mmuller)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mmuller &raquo;</TD></TR><TR><TD CLASS="quote">you dont need to wire a knock sensor with a p28</TD></TR></TABLE>
doh! oh yeah..forgot he's runnin a P28! thanks Muller.
Old Mar 9, 2005 | 08:14 AM
mmuller's Avatar
Mad Scientist
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Katman &raquo;</TD></TR><TR><TD CLASS="quote">doh! oh yeah..forgot he's runnin a P28! thanks Muller.</TD></TR></TABLE>
hehe we know you know. we know your the king arroun heerr
Old Mar 9, 2005 | 10:47 AM
intake's Avatar
B A N N E D
no knock sensor?? or should i just in case?
Wierd,, today maybe less then a hr ago, i tried Gunning her and she wiouldnt go passed 4.5k in 1-2 gr but in 3rd all the way to 8.5 * engine nice and warm passed the line *
Mother ****** sometimes i just want to kill myself when it comes to this bullshit, i should have stuck with a acura cl automatic LOL
Old Mar 9, 2005 | 12:18 PM
93turbo16's Avatar
the ecu has no knock support, you don't need to wire it.
Old Mar 9, 2005 | 12:29 PM
Katman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by intake &raquo;</TD></TR><TR><TD CLASS="quote">no knock sensor?? or should i just in case?
nah you dont have to wire in the KS, it'll be pointless because as already mentioned, there's no KS support on P28 ecu's.
wtf? 4500rpm redline in 1-2nd...then 8500redline in 3rd? makes no sense....you getting any check engine lights?
you're cam & crank timing correct? does the engine bog when you get on the throttle?
Old Mar 9, 2005 | 02:07 PM
intake's Avatar
B A N N E D
No check engine lights at all
No bogging when i get on the throttle either.. Its SOO odd..
Old Mar 10, 2005 | 10:09 AM
intake's Avatar
B A N N E D
Old thing last nite, Its gotta be my wiring on my JDM gauge cluster.. Cause it said it was warm... But it wasnt.. and when i tried punching it.. 1-4th gears i couldnt pass 4.5k * WTF *
But later that nite when she was really warm, i was reaching 8.5k in everything gear.. i was kinda tipsy so i cant remember if VTEC was working or not LOL
Knock sensor is out of the question.. hmmmm all i can think is newer injectors???.. is the 00 JDM ITR injectors and straight swap?.. maybe im not getting enough Fuel ?
No check engine Lights either
Old Mar 11, 2005 | 02:00 PM
intake's Avatar
B A N N E D
Situation LOL": i checked my timing and it was running LEAN as ****.. so i advanced it alot.. let my car run till warm..
Ran her and everything is fine.. it was my timing the whole time
chirped 3rd with ease
Old Mar 12, 2005 | 05:29 PM
Katman's Avatar
cool... have fun
GlennKDM
Oct 9, 2017 11:55 PM
villaluz14
Feb 1, 2012 08:04 AM
technine
Jan 17, 2008 10:43 AM
VTC_CiViC
Dec 26, 2003 09:41 AM
Malgerus
Jun 7, 2002 10:01 AM
