98 Spec Vs 96-97 Spec
engine = i think the 98spec uses the ctr intake cam and the "jdm 4-1" header
tranny = 98spec has a gsr 4th and 5th gear, with a 4.785 fd
brakes = 5lug 11" vs. 96 4lug (4x114.3)
suspension = 96spec has 24mm front, 22mm rear, 98spec has 25mm front 23mm rear. The rear compensator arm is different (stronger?) the spring rates also changed a little.
Exterior = HID lights
Wheels = 96spec 15" wheels 98spec has 16" wheels.
other than that i cant think of much.
Difference between ITR's:
https://honda-tech.com/zerothread?id=163515
https://honda-tech.com/zerothread?id=617623
https://honda-tech.com/zerothread?id=86124
But if you had seen this you would have known... : http://www.albinoblacksheep.com/flash/posting.php
[SARCASM] I think this might have been covered once or twice [/SARCASM]
https://honda-tech.com/zerosearch
say bye to my B18
Jul 5, 2011 11:10 PM
ekim952522000
Dec 12, 2005 05:50 PM
sir2ef-8
Aug 10, 2004 09:14 PM
