Almost have all my MPFI stuff ( Pics)
Old Mar 8, 2005 | 10:57 AM
Stoich's Avatar
Default Almost have all my MPFI stuff ( Pics)
I think i have almost every thing i need to get this done
I got the Intake Mani front an Si
Risitor Box with Plug
Si Injectors ( with that part of the harness)
im still hunting for a PM6 Ecu and Si Dizzy
is there anything else im missing?
Old Mar 8, 2005 | 10:58 AM
Stoich's Avatar
Default Re: Almost have all my MPFI stuff (Stoich)
i have been reading the various write ups on the conversion and i got the injector wiring understood
but what i dont get iswhat is done with all the extra wires that seem to be coming out of both ends of the injector harness as you can see in that last pic
Is this a good deal ?
http://cgi.ebay.com/ebaymotors...=WDVW
Old Mar 8, 2005 | 11:17 AM
NikoZai's Avatar
4 wires go to the ECU and 4 go to the resistor box. The resistor box's yellow/black wire ties into the yellow/black wire on the drivers side 10/12 pin firewall connector.
This is important - These wires go to the main relay, they are 12v+.
From the injector wiring you just got, the colors match like this:
DX side red wire, goes to injector side liht blue wire.
DX side yellow wire, goes to injector side brown wire.
then run 2 new wires for injector #2 and #4 - #2 is pin A3 at the ECU plug, #4 is A7 at the ECU plug.
Or you can pay rywire.com to do it all for you.
And if its reconditioned for 70 thats not too bad, used i would shoot for $40
Check your local classifieds (criagslist) and see whos got one. And search the classifieds on H-T, maybe someone has one to send to you cheaper.
Old Mar 8, 2005 | 11:26 AM
crxtreme89h's Avatar
Man, I don't know. $90 seems a lil steep for a used Dizzy. However, the wires hanging out are fine.
Old Mar 8, 2005 | 02:08 PM
miller.91.HB's Avatar
Default Re: Almost have all my MPFI stuff (crxtreme89h)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxtreme89h &raquo;</TD></TR><TR><TD CLASS="quote">Man, I don't know. $90 seems a lil steep for a used Dizzy. However, the wires hanging out are fine. </TD></TR></TABLE>
90? They are asking for 50 in shipping so the total would be 130 bucks. I wouldn't spend that much on a used one. New is only 160 plus 24 for shipping from Distributor King. Plus you can get a 10% discount if you tell them your from H-T.
Old Mar 8, 2005 | 03:23 PM
dr_latino999's Avatar
Default Re: Almost have all my MPFI stuff (miller.91.HB)
Less actually, I payed a little over 145$ new from Distributor King for my A6 distributor.
Old Mar 8, 2005 | 03:24 PM
Default Re: Almost have all my MPFI stuff (dr_latino999)
Oh, and you need an SI throttle body!
Old Mar 8, 2005 | 03:28 PM
regime's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by miller.91.HB &raquo;</TD></TR><TR><TD CLASS="quote">90? They are asking for 50 in shipping so the total would be 130 bucks. I wouldn't spend that much on a used one. New is only 160 plus 24 for shipping from Distributor King. Plus you can get a 10% discount if you tell them your from H-T.</TD></TR></TABLE>
HAHA ive sold one for 150 once
Old Mar 8, 2005 | 05:02 PM
Stoich's Avatar
Default Re: Almost have all my MPFI stuff (regime)
cant i use the one that is in the first pic?
Old Mar 8, 2005 | 09:54 PM
BlingBlingCivic's Avatar
i didn't see it in the pics, but you need a fuel rail and si fuel line (it's longer i guess)
Old Mar 9, 2005 | 09:46 AM
Default Re: Almost have all my MPFI stuff (BlingBlingCivic)
You can use the stock fuel line.
Old Mar 9, 2005 | 09:47 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Stoich &raquo;</TD></TR><TR><TD CLASS="quote">cant i use the one that is in the first pic?</TD></TR></TABLE> Sorry, I didn't see the TB in the background me
Old Mar 9, 2005 | 09:57 AM
FalkenSiR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dr_latino999 &raquo;</TD></TR><TR><TD CLASS="quote">You can use the stock fuel line.</TD></TR></TABLE>
Yup, had the same question. Did it and fits perfect So used my old one
I even went to honda and the si fuel line is $79 !!!!
Old Mar 9, 2005 | 10:06 AM
PaImportTuner's Avatar
Default Re: Almost have all my MPFI stuff (fast88std)
might as well go obd1 buddy. if you need ecu and dizzy go obd1
Old Mar 9, 2005 | 10:13 AM
Ash J. Williams's Avatar
Good, Bad…I'm the one with the gun
From: Trapped in time, Surrounded by evil, Low on gas
Default Re: Almost have all my MPFI stuff (PaImportTuner)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PaImportTuner &raquo;</TD></TR><TR><TD CLASS="quote">might as well go obd1 buddy. if you need ecu and dizzy go obd1</TD></TR></TABLE>
gathering info on this...
what particular ECU and distributor, ( part numbers would be appreciated).
stan
Old Mar 9, 2005 | 12:38 PM
Default Re: Almost have all my MPFI stuff (Stan D)
<FONT SIZE="3">Non-Vtec OBD-1 SOHC</FONT>
___________________
ECU: P06
Distributor - TD41U
<FONT SIZE="3">VTEC OBD-1 SOHC</FONT>
___________________
ECU: P28
Distributor - TD42U
Old Mar 9, 2005 | 12:54 PM
thank you much, saved
stan
Old Mar 9, 2005 | 01:40 PM
gnar kill's Avatar
not to try and sell something cause I know there is a spot for classifieds but I am doing a complete obd1 mini me swap to me 91 si so I will hve what you need left over if you wanted to wit two weeks or something.....IM me if you are interested
1SlowSi
Jul 26, 2009 11:34 AM
MBlake55
Jul 18, 2008 10:06 AM
Dohc 4door Rye
Nov 15, 2005 05:13 PM
boostin b16
Mar 2, 2003 03:03 PM
joeyitr309
Oct 21, 2001 05:05 PM
