In-Dash 6 Disc CD Changer
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Psykik »</TD></TR><TR><TD CLASS="quote">Does anyone know if this unit will fit/connect in a 1997 CR-V without modification?
Thanks,
Rob
(sorry for a slight hijack)</TD></TR></TABLE>
yes it will fit I've got one on my 91 Accord.
Thanks,
Rob
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Qfactor »</TD></TR><TR><TD CLASS="quote">
yes it will fit I've got one on my 91 Accord.</TD></TR></TABLE>
it will not fit the plugs are different 98+ hondas, he is talking about the indash changer built into the radio.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99accordexv6 »</TD></TR><TR><TD CLASS="quote">it will require modification but its quite simple...just get a harness and wire it to your existing harness</TD></TR></TABLE>
thank you for clarifing... some people think just because the plugs don't fit/match is over. there's always ways around. but I do have the in-dash 6 disc changer into a 91 accord. you can buy the pigtail plug at the dealer..
Hey man, got a pic of it installed?? I may switch back to OEM if it's a nice player....do they play burned CDs (if the files are saved as .wavs)??
I wonder if there's a way to make a plug in harness adapter using both styles to go from new plug to old plug and vice versa....hhrmm......
If this Honda in-dash radio will fit in older Hondas and just requires a way to convert from the old connector (vehicle side) to the radio side (newer connector), it still interests me as a possibility.
Is there such an aftermarket adapter or must someone compare the schematics and build their own?
Thanks,
Rob
Thanks,
Rob
