WILL A CL STOCK DECK FIT?!?!?
Old Sep 7, 2003 | 06:09 PM
hakemjmba's Avatar
Default WILL A CL STOCK DECK FIT?!?!?
ok i asked before but i want to make sure. will a 97 cl stock cd player fit in my 94 del sol? if it wont fit what kind of modifications will have to be made? please i need an answer, i need to play some music in my car thanks!
Old Sep 7, 2003 | 06:13 PM
BauleyCivic's Avatar
Risky Business
Default Re: WILL A CL STOCK DECK FIT?!?!? (hakemjmba)
if it has an anti-theft device then you will need the code from the factory to activate it...otherwise i believe it will just go right in
Old Sep 7, 2003 | 10:02 PM
hakemjmba's Avatar
Default Re: WILL A CL STOCK DECK FIT?!?!? (BauleyCivic)
up
Old Sep 8, 2003 | 01:49 AM
hakemjmba's Avatar
up
Old Sep 8, 2003 | 06:12 AM
1 point 6's Avatar
Down Since Day 1
Community Builder
Community Influencer
Well to my knowledge there are only 2 sized decks, DIN and double DIN. Double DINs are like big chevy decks, if it looks like a normal sized CD player it will fit.
Obviously if its huge....draw your own conclusion.
Old Sep 8, 2003 | 08:03 AM
TurboBumblBee's Avatar
Default Re: (1 point 6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1 point 6 &raquo;</TD></TR><TR><TD CLASS="quote">Well to my knowledge there are only 2 sized decks, DIN and double DIN. Double DINs are like big chevy decks, if it looks like a normal sized CD player it will fit.
Obviously if its huge....draw your own conclusion.</TD></TR></TABLE>
right and wrong.. lots of newer cars have radios that are designed to contour the dash like the new 3.2 ct/tl and new accord.. they are not double din.. but to get to your question it it will fit, just get the code for it also or its no good..
Old Sep 8, 2003 | 01:09 PM
rjr162's Avatar
Default Re: (Hybrid95CivicEX)
and there is also 1.5 din, and some screwed up cars have a factory like 2.5 or 3 din... really dumb. Plus older Olds I think it was used CRT's
Old Sep 8, 2003 | 01:25 PM
hakemjmba's Avatar
so the hardness and stuff should plug right in? basically plug and play?
Old Sep 8, 2003 | 01:50 PM
Default Re: (hakemjmba)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hakemjmba &raquo;</TD></TR><TR><TD CLASS="quote">so the hardness and stuff should plug right in? basically plug and play?</TD></TR></TABLE>
yes it should all be the same
toothpickvic
Honda Fit
Aug 23, 2008 06:16 PM
Travis2262
Audio / Security / Video
Dec 5, 2007 03:05 PM
ocdcivic
Jan 1, 2005 10:19 AM
STEV3-O
13
Sep 2, 2003 05:25 PM
Splangtastic
Jul 17, 2003 03:25 PM
