quick ? need quick answer
Old Mar 7, 2005 | 08:11 PM
Tokyo_X-treme_Racer's Avatar
New User
Default quick ? need quick answer
I want to remove my b16 valve cover, I've removed all bolts and can't budge it? Is there any other hidden bolts? or maybe I just need to force it out?
Old Mar 7, 2005 | 08:14 PM
PHOBIA's Avatar
its only the bolts on the top of the valve cover. there ar eno hidden bolts.take a soft malet and knock the side of it a little and it should come right off.
Old Mar 7, 2005 | 09:20 PM
Aespooncivic's Avatar
Default Re: quick ? need quick answer (Tokyo_X-treme_Racer)
theres one in the trunk that u need to remove..thats the hidden bolt..
Old Mar 7, 2005 | 09:22 PM
mikehawkBUiLT's Avatar
Default Re: quick ? need quick answer (Aespooncivic)
theres 6 acorn nuts and 4 regular nuts.
Old Mar 7, 2005 | 09:53 PM
PHOBIA's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Aespooncivic &raquo;</TD></TR><TR><TD CLASS="quote">theres one in the trunk that u need to remove..thats the hidden bolt.. </TD></TR></TABLE> extremely help full , right on dude
Old Mar 7, 2005 | 10:03 PM
GapxGuy's Avatar
Sushi Buffet Champion
Have you tried taking off your spark plug cables?
Old Mar 7, 2005 | 10:11 PM
_Cyclone_'s Avatar
Default Re: quick ? need quick answer (GapxGuy)
I'm guessing you're not blind, and you took off all the bolts that you could see. If you have done this right, all you have to do is find a good place to grip it with your hands and pull straight up. Personally, I wouldn't hit anything on the cylinder head with a mallet... you could possibly damage the mating surfaces and then you'll leak oil afterwards. My guess is the rubber gasket has probably hardned somewhat and taken the shape of the mating surfaces. Once this happens, it makes it a little more difficult to remove, but don't be afraid to pull straight up with your hands. You'll likely have to get the new valve cover gasket from Honda if it's in that condition.
Old Mar 7, 2005 | 10:14 PM
Luserkid's Avatar
Default Re: quick ? need quick answer (CycloneBlue_1.6EL)
Get a screwdriver and slowly pry it.
Old Mar 8, 2005 | 08:38 AM
PHOBIA's Avatar
i didnt mean like a hammer i ment a rubber mallet and verry gently tap it at the corners.
gsrswap
18
May 7, 2007 11:06 AM
Esdelota
10
Oct 18, 2006 05:50 AM
EJ8 GSR-T
24
Dec 2, 2004 09:33 PM
SL!M
Apr 26, 2003 09:06 PM
crxaddikt
Sep 19, 2002 10:08 PM
