performing 5gen auto to manual swap starter question
Old Mar 7, 2005 | 07:36 PM
ionic_slim's Avatar
Default performing 5gen auto to manual swap starter question
If I use a f22a 4gen transmission, do I use the starter for that generation? Reason I ask is because isn't the connecting plug in the starter is different for a obd1?
Old Mar 8, 2005 | 04:31 AM
kulrevon's Avatar
Default Re: performing 5gen auto to manual swap starter question (tazmoe)
is there even a plug on the stater. its a bolt for power. and one wire for the solonoid right? I believe the wire just has a female blade connector on it.
Id use the starter that fits on the tranny. I dont think a 5th gen auto starter would fit on a 4th gen manual tranny but might as well try if you dont have the other.
Old Mar 8, 2005 | 05:26 AM
ionic_slim's Avatar
Default Re: performing 5gen auto to manual swap starter question (kulrevon)
Thanks! I was confused with the b-series swap alternator's plug...also the flywheel should be the same as the transmission I'm getting or stick with a 5gen manual h22a flywheel?
Old Mar 8, 2005 | 08:32 AM
kulrevon's Avatar
flywheels should be the same on both the h and f series.
komat
Oct 28, 2013 02:36 PM
xkrazyxjbrkerx75
Apr 29, 2009 01:23 PM
dschenke
Mar 29, 2009 01:16 AM
tyler100
15
Jul 25, 2008 03:20 PM
Jeff C
Apr 10, 2002 01:15 PM
