b16 obd2 into a 5g......ecu/wiring help
Old Mar 7, 2005 | 07:27 PM
SASi's Avatar
Default b16 obd2 into a 5g......ecu/wiring help
Here is what I have. I have a 1995 Civic Si. Here is what I am putting in, a JDM B16a that is obd2. My question is......what do i have to do to make this swap work with the different ECU's. I will pay a little more so that it runs perfect. I have the full uncut ECU/harness/wiring from the swap. I know it should be easy because my car is already wired for VTEC.....please point me in the right direction,
thanks
Yes I did a search before anyone asks, and the closest thing I found was from March 04 and the car was a DX(non-vtec).....all info is much appreciated.
Old Mar 7, 2005 | 07:51 PM
civictildeath's Avatar
Default Re: b16 obd2 into a 5g......ecu/wiring help (SASi)
http://tech.hybridgarage.com/t....html
may help it is for b16a2 dont know how close the two are
Old Mar 7, 2005 | 08:00 PM
SASi's Avatar
thankyou.......I have seen that one and have it saved as one of my favorites just incase i nead to reference when I do the install. In some of the threads I was reading ( which never said anything about b16a obd2 into an obd1 car ), they reccomened a guy named kenji.
I have never heard of the guy though.
Old Mar 7, 2005 | 09:45 PM
SASi's Avatar
after much research and still no hard answers....it might be that the P28 is the way to go??? If anyone does help me out here.....this might make a difference. I have P&P head, CTR cams, and CTR pistons.....all else is stock for now, because the engine is sitting in the garage but i also plan on I/H/E.
thanks again if anyone knows about obd2 in obd1 cars or has done this themselves
Old Mar 8, 2005 | 11:42 PM
SASi's Avatar
anyone ???
Old Mar 8, 2005 | 11:52 PM
JDMlyfestyle's Avatar
Yes go P28. run the mugen program its a rich running chip. but ur running around a 11.8:1 CR that will suit you just fine
here is how you do the dizzy
1234
5678 Distributor Plug Pinout #'s
910
wiring harness side
1. Yellow w/ green
2. Blue w/ green
3. orange Blue
4. orange
5. blank
6. blue w/ yellow
7. white/ blue
8. white
9. Blue
10. Black w/ yellow
Dizzy side
1. yellow w/ green
2. Blue w'/ green
3. White w/ blue
4. white
5. blank
6. Blue w/ yellow
7 white w/ blue
8. White
9. blue
10. Black w. yellow
Alternator
obdI plug(new) ---------------- obdII plug (old)
blk/yel ---------------- blk/yel
wht/blu ---------------- wht/blu
wht/yel ---------------- wht/red
Blue ---------------- wht/grn
Old Apr 9, 2005 | 09:54 PM
SASi's Avatar
Default Re: (JDMlyfestyle)
thanks for the help...I am going to give it a shot
karmaworks199
Nov 8, 2015 05:27 PM
Sagara09
12
Jan 9, 2012 08:11 AM
gotboosthatch
Feb 16, 2008 03:44 PM
.PLUMMM
Jan 9, 2008 12:30 AM
NOman0608
May 12, 2007 08:39 PM
