do all swaps do that?
Old Mar 7, 2005 | 07:23 PM
futurefastguy's Avatar
Default do all swaps do that?
i have now seen 2 civic with swaps in them that do the same thing. when they are in idle, it seems like the motor keps reving by itself. it revs maybe up tp 1800k and then back to 1000k. do all swapsdo that, just wondering.
Old Mar 7, 2005 | 07:25 PM
v0lcom27's Avatar
Default Re: do all swaps do that? (futurefastguy)
Sounds like a bad 02 sensor. All swaps dont do that.
_BEN_'s Avatar
No there is something wrong. Could be timing, vacuum tubes, or other stuff.
Old Mar 7, 2005 | 07:27 PM
nub.96ek's Avatar
Default Re: do all swaps do that? (_BEN_)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by _BEN_ &raquo;</TD></TR><TR><TD CLASS="quote">No there is something wrong. Could be timing, vacuum tubes, or other stuff. </TD></TR></TABLE>
Mine did that when I first put it in... I had a dirty IAC valve.
Old Mar 7, 2005 | 07:33 PM
1slowhatchie's Avatar
Default Re: do all swaps do that? (nub.96ek)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nub.96ek &raquo;</TD></TR><TR><TD CLASS="quote">
Mine did that when I first put it in... I had a dirty IAC valve.</TD></TR></TABLE>
or it might be your fitv
Old Mar 8, 2005 | 10:50 AM
B20badboy's Avatar
The IAC under the throttle body needs adjusting no biggie.
Old Mar 8, 2005 | 11:01 AM
Ls_V_TurboSi's Avatar
Default Re: do all swaps do that? (B20badboy)
nope.. not a good sign when it does that...
Old Mar 8, 2005 | 12:25 PM
John in NorCal's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B20badboy &raquo;</TD></TR><TR><TD CLASS="quote">The IAC under the throttle body needs adjusting no biggie.</TD></TR></TABLE>
what is IAC?
how is it adjusted?
Old Mar 8, 2005 | 12:55 PM
jeef84's Avatar
Default Re: do all swaps do that? (John in NorCal)
http://www.emotors.ca/Articles/article.aspx?id=97
The valve that is pictured is located right under your throttle body, and has two coolant lines going to it. Take off the small coolant hoses, and the two 10 mm bolts holding to to the TB and check it.
Old Mar 9, 2005 | 08:52 AM
black_hatch's Avatar
Default Re: do all swaps do that? (jeef84)
IAC valve diffinitely the spring pops it out too much and it makes the idle go up and down. annoying but sounds like you have some hard core cams.... lol easy fix. take it off and clean it and tighten the spring into it again. 5 - 10 minute fix and walla .... good as new.
good luck
Old Mar 9, 2005 | 09:27 AM
PHOBIA's Avatar
its 3 bolts on a b16-b18
Old Mar 9, 2005 | 09:40 AM
handa's Avatar
Default Re: (PHOBIA)
This thread is perfect for me
I've been figuring something similar all my life!
Check https://honda-tech.com/zerothread?id=1170181
Old Mar 9, 2005 | 09:42 AM
PHOBIA's Avatar
if you want to find out if its the iac get a piece of a cereal box and cut out a section of it. loosen the bolts on the iac and slid it inbetween the iac valce and the manifold. tighten it down and fire it up.if it goes away there is your problem.
Old Mar 9, 2005 | 09:44 AM
Ninety5Ex's Avatar
I always wanted to know why people's hondas do that. next time I see someone at a light that thinks they they got something cool going on i'll let them know they have a cool malfunction
Old Mar 9, 2005 | 10:45 AM
JDM_Armenian's Avatar
Default Re: (Ninety5Ex)
adjustments and fine tunning needed.
all swaps are not like this.
Old Mar 9, 2005 | 10:51 AM
1sikhatch's Avatar
my teg used to do the same thing, then it would idle steady after it warms up
Spikey640
Aug 14, 2008 09:40 PM
mart1976
Nov 23, 2006 10:43 AM
civicEXtreme
Oct 7, 2005 11:12 AM
done
Apr 6, 2005 03:59 PM
JCCOOL43
Jun 13, 2003 03:15 AM
