Important Type-R wing question !!!!!!!!!
Old Mar 7, 2005 | 02:12 PM
Spoogen_1's Avatar
Default Important Type-R wing question !!!!!!!!!
I wanted to but a type r wing for my 98 gs. i already have the gsr wing on it with brake light. the guy i was going to get the type r wing from sed it wont work cuz my holes are much bigger cuz of the wires for my stock wing. he sed itll work but ill have big holes stilll where water and what no can come in. i never heard this before, but maybe someone can help me with some ifo cuz right now im not sure what to think.
Old Mar 7, 2005 | 02:18 PM
Built to Spill's Avatar
el diablo
Default Re: Important Type-R wing question !!!!!!!!! (Nexus131)
As far as i know all the holes are the same size. An R wing is a direct bolt-on to your trunk.
Old Mar 7, 2005 | 02:22 PM
Rtistik.'s Avatar
Default Re: Important Type-R wing question !!!!!!!!! (Built to Spill)
only the comptech R wing will cover up the big hole..there's only one hole that i believe will show, and that's the bigger one where the wires run through..
Old Mar 7, 2005 | 02:27 PM
Spoogen_1's Avatar
Default Re: Important Type-R wing question !!!!!!!!! (rtistik)
so your saying the comptech r wing is the onyl one that will cover everything. What makes the differnece? is it the base of it of something?
Old Mar 7, 2005 | 02:40 PM
SMZ GSR's Avatar
When I put OEM ITR wing on my 98 GSR it left 2 holes exposed.
The ITR wing will bolt on using the 4 small holes. The GSR wing had an extra stud holding down the wing on the drivers side and the wires went thru the hole on the passanger side.
Old Mar 7, 2005 | 03:50 PM
Spoogen_1's Avatar
Default Re: Important Type-R wing question !!!!!!!!! (SMZ GSR)
1. why did they have that extra hole on the driver side. and
2. what is the brand type r wing that i need to get that covers all the wholes. i dont know what brand makes a replica one that i can use for that.
Old Mar 7, 2005 | 05:30 PM
Spoogen_1's Avatar
Old Mar 7, 2005 | 11:23 PM
TA Performance's Avatar
HANG OUT WITH YOUR **** OUT!!
Old Mar 7, 2005 | 11:28 PM
Markis.'s Avatar
Default Re: Important Type-R wing question !!!!!!!!! (Boro_DC2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boro_DC2 &raquo;</TD></TR><TR><TD CLASS="quote">HANG OUT WITH YOUR **** OUT!! </TD></TR></TABLE>
LMAO
Old Mar 8, 2005 | 02:01 AM
01-0720's Avatar
Default Re: Important Type-R wing question !!!!!!!!! (HoodsiR)
you need to get the comptech type r wing for a gsr, thats the only one that will fit perfect and cover up all the holes, i also believe you can get them with or with out a brake light also
Old Mar 8, 2005 | 02:20 AM
mckenzie's Avatar
there are 5 holes i believe...4 for the screws for the wing, 1 bigger one for the wires
Old Mar 8, 2005 | 06:34 AM
Spoogen_1's Avatar
Default Re: Important Type-R wing question !!!!!!!!! (superpho)
Can someone get a pic comparing the two spoilers so i can see how the base of it is different?
njmad
Nov 2, 2009 03:16 PM
Dfwdc2R
Feb 21, 2007 08:01 PM
Mr.DC2TurBo
Aug 19, 2004 08:06 AM
droppedcivo
May 2, 2003 01:27 PM
Fez
Aug 28, 2002 10:22 PM
