Is it safe to take top heat shield off?
Old Mar 7, 2005 | 07:12 AM
IntegraLs94Cam's Avatar
Default Is it safe to take top heat shield off?
I searched around and did not find much ... My exhaust rattles bad at 3-3.5rpm ... i have a high flow cat header and catback... i belive the rattle is coming from the heat shield above the high flow cat .. some peolpe tell me not to take it off because something could get on fire under there ... I really dont think something would unless some paper got under there and stayed there for a while.... anyone ever take there heat shield off on the top of the cat befor is it safe and easy to get off? just some bolts right ?
Old Mar 7, 2005 | 07:14 AM
EnjoyTheRideDC2's Avatar
Default Re: Is it safe to take top heat shield off? (IntegraLs94Cam)
its safe IMO, and bolts on and off. I've never heard otherwise, and heatshields do annoy me when they get loud. Only thing is the area above it could get pretty warm.....
Old Mar 7, 2005 | 07:16 AM
Default Re: Is it safe to take top heat shield off? (EnjoyTheRideDC2)
do i have to take off the cat to get to the bolts or not ?
Old Mar 7, 2005 | 07:35 AM
BuyImports2's Avatar
i had all of my heat shields under my car removed. no problems, no rattling
Old Mar 7, 2005 | 08:01 AM
dFreezy's Avatar
Default Re: (BuyImports2)
its completely safe, i've never heard of a fire occurring as a result of removing the heatshield.
Old Mar 7, 2005 | 08:05 AM
AlxSiR7's Avatar
get rid of all your heatshields.. i'd go insane if i had to hear them rattle all the time (which they will eventually do!!)
Old Mar 7, 2005 | 08:15 AM
1 point 6's Avatar
Down Since Day 1
Community Builder
Community Influencer
Default Re: Is it safe to take top heat shield off? (AlxSiR7)
mine rattled on my EG, just took them off about a year ago and ive had 0 problem. go for it, its just a thin piece of aluminium.
Old Mar 7, 2005 | 09:16 AM
Default Re: Is it safe to take top heat shield off? (1 point 6)
isnt there a big long heat shield that runs along the middle of the car .. did you take that off to?
Old Mar 7, 2005 | 09:18 AM
IVI's Avatar
IVI
no heat shields here, been fine for over 4 years.
Old Mar 7, 2005 | 11:40 AM
evo45's Avatar
Default Re: Is it safe to take top heat shield off? (IVI)
Had mine removed for 2 years on my 96' civic coupe and no problems.
Old Mar 7, 2005 | 12:19 PM
darknessplayboy's Avatar
what about the header heatshield? on my gs it look all rusty and I don't like the look of it. If I remove it will it make my car sound louder?
Old Mar 7, 2005 | 12:34 PM
Chris F's Avatar
Default Re: (darknessplayboy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by darknessplayboy &raquo;</TD></TR><TR><TD CLASS="quote">what about the header heatshield? on my gs it look all rusty and I don't like the look of it. If I remove it will it make my car sound louder?</TD></TR></TABLE>
Very few aftermarket headers have heatshields, for better or worse. Your car will run a little warmer with that radiated heat hitting the radiator, but probably not enough to notice. Most racers use headers with no heat shield or heat wrap.
Also, you will NOT hear a difference, it will not be louder. Ha!
-Chris
Old Mar 7, 2005 | 01:10 PM
oh-k's Avatar
it'll get hot as hell if you do.
Old Mar 7, 2005 | 01:21 PM
garg's Avatar
Default Re: Is it safe to take top heat shield off? (oh-k)
I've got aftermarket headers so I just took my heatshield off, engine bay gets a bit hotter but apart from that its sweet
Old Mar 7, 2005 | 04:24 PM
eficker's Avatar
heat shields were made to be removed.
Old Mar 7, 2005 | 05:06 PM
Davmx's Avatar
Default Re: Is it safe to take top heat shield off? (eficker)
Heatshield is meant to protect the stupid drivers from touching the exhaust manifold directly and others things
Old Mar 7, 2005 | 05:12 PM
Chris F's Avatar
Default Re: Is it safe to take top heat shield off? (Davmx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Davmx &raquo;</TD></TR><TR><TD CLASS="quote">Heatshield is meant to protect the stupid drivers from touching the exhaust manifold directly and others things</TD></TR></TABLE>
Well, the ugly one on the exhaust manifold keeps engine bay temps down, which in turn means more power. YMMV.
Old Mar 9, 2005 | 04:40 AM
Default Re: Is it safe to take top heat shield off? (Chris F)
i guess im taking it off
Old Mar 9, 2005 | 05:11 AM
RallyRedGT-V6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oh-k &raquo;</TD></TR><TR><TD CLASS="quote">it'll get hot as hell if you do.</TD></TR></TABLE>
No... it wont.
Old Mar 9, 2005 | 05:34 AM
Default Re: Is it safe to take top heat shield off? (RallyRedGT-V6)
where would it get hot ... near the shifter ?
sitinduk
Jan 31, 2008 06:17 PM
97ek9
Nov 5, 2007 08:20 AM
95GS-R801
Sep 3, 2007 12:09 PM
intgraCA
May 23, 2007 04:43 PM
anht
Sep 15, 2005 07:33 PM
