feels like i lost horespower after using Seafoam
Old Mar 7, 2005 | 01:52 AM
srv3fender's Avatar
Default feels like i lost horespower after using Seafoam
Ok i did a semi tune up, sprayed the tb with carb cleaner and poured seafoam into my brake booster line. Also replaced fuel filter, pcv, techron in the tank, and cap and rotor. I only used about 1/4 can for the carb cleaner and seafoam. I wanted to use more but i had to stop cause i was smokin up my neighborhood. So after doing this i felt like i had lost horespower like maybe 10-15 hp. Anybody know if i did something wrong.
Its an 88 crx with a d16y8 in it.
also when i was changin the fuel filter the gasoline that came out was clear, but i poured the gas out of the old filter into a cup and the gas was foggy brown and there was some brown dirt at the bottom. I dont think it had ever been changed. Anyone ever had this happen before.
your Help is greatly appreciated!
Old Mar 7, 2005 | 02:22 AM
Blind-Fashion's Avatar
You didint change your plugs after using sea foam? i think your problem lies there.
Old Mar 7, 2005 | 06:10 AM
l e o h j's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blind Fashion &raquo;</TD></TR><TR><TD CLASS="quote">You didint change your plugs after using sea foam? i think your problem lies there. </TD></TR></TABLE>
x2
Old Mar 7, 2005 | 06:18 AM
fireant's Avatar
Default Re: (leohj)
do the plugs and report back! People need to know!
kulangot's Avatar
Default Re: (leohj)
x4.....and that is normal for the fuel filter....it is a filter..
Old Mar 7, 2005 | 06:21 AM
thatbluecrx's Avatar
Default Re: (sirq2u)
oil change after seafoam!!!!
Old Mar 7, 2005 | 06:42 AM
fireant's Avatar
Default Re: (thatbluecrx)
He didnt put it into his valve cover, just the IM, but it wouldnt hurt to change the oil.
Old Mar 7, 2005 | 06:59 AM
srv3fender's Avatar
Default Re: (fireant)
oil just got changed about 2 weeks ago , cast semi sen 10-30
whats the best plugs i could get at a local auto parts store
Old Mar 7, 2005 | 07:01 AM
fireant's Avatar
Default Re: (srv3fender)
The stock D16Y8s NGKs are a great plug.
Old Mar 7, 2005 | 07:02 AM
srv3fender's Avatar
who carries ngk
Old Mar 7, 2005 | 07:11 AM
Chronic_SMOKE's Avatar
autozone, kragen etc.
Old Mar 7, 2005 | 08:30 AM
fireant's Avatar
Default Re: (Chronic_SMOKE)
O-Reily's
Old Mar 7, 2005 | 12:43 PM
LSVTEC 91 Civic's Avatar
Banned
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by srv3fender &raquo;</TD></TR><TR><TD CLASS="quote">who carries ngk</TD></TR></TABLE>
Advance auto has the BKR6E-11 , good plug.
Old Mar 7, 2005 | 01:21 PM
kulangot's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fireant &raquo;</TD></TR><TR><TD CLASS="quote">O-Reily's</TD></TR></TABLE>
Old Mar 7, 2005 | 03:48 PM
green91's Avatar
the seafoam probably cleaned alot of the carbon off your pistons which lowered your artificially high compression ratio back down to normal and u lost power
Old Mar 7, 2005 | 03:58 PM
doublethink's Avatar
Default Re: (green91)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by green91 &raquo;</TD></TR><TR><TD CLASS="quote">the seafoam probably cleaned alot of the carbon off your pistons which lowered your artificially high compression ratio back down to normal and u lost power</TD></TR></TABLE>
i have seen posts in the past where guys left then engine with carbon buildup bc it actually made more power that way....
Old Mar 7, 2005 | 04:18 PM
fireant's Avatar
If that's the case, srv3fender, be sure to keep tabs on your oil level.
Old Mar 7, 2005 | 05:03 PM
green91's Avatar
i wouldnt be concerned about the oil level... after years of driving the carbon builds up in the combustion chamber and increase the c/r.. and when using top engine cleaning products like seafoam, it cleans it out, thus effectively lowering the c/r and making it "loose performance"
Old Mar 7, 2005 | 05:20 PM
fireant's Avatar
but wouldnt that "free up" the rings any?
Old Mar 7, 2005 | 05:34 PM
green91's Avatar
carbon doesnt typically build up in areas of friction like the cylinder walls or rings
Old Mar 7, 2005 | 06:01 PM
fireant's Avatar
I guess I'm oil paranoid
Old Mar 8, 2005 | 05:08 AM
green91's Avatar
unless you can tell you are burning oil off out the exhaust after youve ran it for about 30 mins or so, i wouldnt be concerned.. but it is always a good idea to check your oil level anyway
cholder919
Sep 11, 2011 05:03 PM
redDAinteg
Feb 1, 2008 06:53 PM
SiMateoAko
11
Feb 23, 2006 08:23 AM
NCTUAN03
Apr 20, 2005 07:37 AM
srv3fender
22
Mar 7, 2005 11:27 AM
