obd-2b gsr motor to obd-1 eg hatch
car: 1993 hatchback SI
swap:99 gsr with obd-b2, running a p30
prob:p30 5th gear drives back to 115-ish MAX
question: what ecu can i run that'll have 5th gear to redline?
also if i chip the p30 what are my selections/ set-up?
how are you running a p30 on a GSR motor? Im assuming that its stock. cause if it is u are losing the IAB function and the secondary butterflies are not opening.
The p30 is a 8296 Redline
Vtec engagement 5875
Top speed 115 MPH.
Top speed 115 MPH.
i dont know much about ecu but i do know its a p30.. and your right about the redline,cut-off,vtec JDMlyfestyle.
well my question is what should i do about the ecu? buy a new one?chip it?
ive heard that p30 were hard to find/expensive.
buy a p72 obd1 ecu from a 94 or 95 and it plugs right in, you will have to wire up secondary butterflies and a knock wire but your local tunner shop can most likely do that in short enough time you can wait for it to be done and shouldnt cost much. Dont mess with chipping the ecu go with a s100 or s200 hondata or neptune management system
secondary butterflies only come in the newer b18c1 right?? well im planning on changing it to a skunk 2 IM before doing anything to my ecu..
do i need to so all the wiring for secondary butterflies and knock wires?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1_slowEG »</TD></TR><TR><TD CLASS="quote">buy a p72 obd1 ecu from a 94 or 95 and it plugs right in, you will have to wire up secondary butterflies and a knock wire but your local tunner shop can most likely do that in short enough time you can wait for it to be done and shouldnt cost much. Dont mess with chipping the ecu go with a s100 or s200 hondata or neptune management system</TD></TR></TABLE>
go with the hondata.........
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMlyfestyle »</TD></TR><TR><TD CLASS="quote">
Top speed 115 MPH.</TD></TR></TABLE>
wow
wow
adikt
14
Mar 26, 2011 08:42 PM
d!ckface
Jan 30, 2007 05:09 PM
Fuster_Cluck
Feb 21, 2003 01:14 AM
