will ek susp. fit on eg??
Rear LCAs do not swap.
Rear shocks can be used by either grinding your EG LCA/damper bushings, or using EK LCA/damper bushings in the EG LCA.
I was not aware the the knuckles didn't swap. I'm not so sure about that, because I know you can put GSR knuckles on both the EG & EK...
vizsual00
24
May 26, 2004 10:09 PM
