Need help with dash lights
My dash lights arent working(they didnt work when i bought the car). I have a 93 coupe. The only things that dont light up are the speedo, tach., etc. and the lights behind my climate control crap(the sliding things)....blinkers work the climate control buttins light up and all my little lights in the dash work, seatbelt, CEL, etc. its not the fuse, could it be the dummer switch???? TIA
It is the dimmer switch. Pull it out and you'll see that it's attached to a 3 wire plug. Try and wiggle each wire around and see if it lights up. It might be a bad connection from one of those wires to the switch, but more than likely it's the switch itself. You'll need to get a new one.
Dimmer switch or check out the headlight switch also... Mine is gettin' sketchy and I have to wiggle the headlight switch a little bit every once in a while.
Silvertune
11
Apr 15, 2012 09:20 PM
Jonathan_ED3
11
Aug 25, 2005 03:47 PM
AMChev
Oct 14, 2003 05:16 AM
