HELP QUICK, IM IN THE MIDDLE OF MY SWAP
Old Mar 6, 2005 | 06:58 PM
Champ White EJ8's Avatar
Default HELP QUICK, IM IN THE MIDDLE OF MY SWAP
motor is in, everything is done, but my ecu isnt pluggin it, i gotta 98 ex with 97 ex motor and 98 ex harness, and a p2p, idk if p2p is obd2a or b, would this prevent me from pluggin in the ecu?
Old Mar 6, 2005 | 07:07 PM
civictildeath's Avatar
Default Re: HELP QUICK, IM IN THE MIDDLE OF MY SWAP (VSM EJ8)
97 and 98 are OBD2 B 99-00 are OBD2 A i dont know for sure if it would stop it from plugging in but i think it would
Old Mar 6, 2005 | 07:09 PM
pdiggitydogg's Avatar
youve got a bit of a problem there
97 being 2a
98 being 2b
Either find the pinout and repin whats different or take it up the *** and buy a harness
Old Mar 6, 2005 | 07:13 PM
Luserkid's Avatar
Default Re: (pdiggitydogg)
Sounds like you got the wrong ecu. Which does it look like?
Old Mar 6, 2005 | 07:15 PM
Good ol' Screwtape's Avatar
Multi-paradigm
i'm sorry i can't stop staring at the *** in your avatar. try again later.
Old Mar 6, 2005 | 07:32 PM
Default Re: (Luserkid)
its a p2p i just dont know its a 96-98 or 99-00
Old Mar 6, 2005 | 08:09 PM
Default Re: (VSM EJ8)
this is my only car and im not pputtin the shitty harness on, should i try a new ecu? or do i have the wrong harness? there is a small grey plug that isnt pluggin in its 2 small for the slot
Old Mar 6, 2005 | 08:14 PM
llxzxll's Avatar
hey luserkid, someone mentioned to me i should contact you about wiring and stuff my city lights...
but newyz, about htat chart...how is a b16a3 out of a del Sol obd IIa? my del Sol VTEC was obd 1. and aren't b16a2's out of civic si's obd2b?
Old Mar 6, 2005 | 08:43 PM
eg crunkmonster's Avatar
Default Re: (llxzxll)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by llxzxll &raquo;</TD></TR><TR><TD CLASS="quote">hey luserkid, someone mentioned to me i should contact you about wiring and stuff my city lights...
but newyz, about htat chart...how is a b16a3 out of a del Sol obd IIa? my del Sol VTEC was obd 1. and aren't b16a2's out of civic si's obd2b?</TD></TR></TABLE>
well the difference between a del sol and ek civics is in the wiring harness itself. in a delsol, the engine harness and interior harness meet at the shock tower and with the EKs, the engine harness goes straight to the ECU, hopes that helps u out.
as for the question up above, sounds like you have the wrong ECU or harness. 96-98 harnesses are the same but the 99-00 harnesses are different. I think the only difference is the ECU plugs. Dont take my word for it but thats all i know about this subject
edit, if all else fails, use the original engine harness and original ECU on the new motor
Old Mar 7, 2005 | 07:03 AM
Default Re: (eg cookiemonster)
yah, i gotta 99-00 civic ex auto harness. guy told me it was 98 ex 5 speed harness... all u liar and scammers r garbage and ur lucky ur hidden by the internet bc id blast all of u.. anyway i had 2 rewire it 2 5 speed and buy a 99 ex ecu.. so bottom line, if u get caught scamming, atleast have the respect 2 tell the truth so some1 can fix it instead of spending 2 hrs switching harnesses for nothing... thanx for all the help 2 every1 in the post
Old Mar 7, 2005 | 07:13 AM
bustah49's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VSM EJ8 &raquo;</TD></TR><TR><TD CLASS="quote">motor is in, everything is done, but my ecu isnt pluggin it, i gotta 98 ex with 97 ex motor and 98 ex harness, and a p2p, idk if p2p is obd2a or b, would this prevent me from pluggin in the ecu?</TD></TR></TABLE>
this is wrong^^^
this is right
96-98 obd2a as far as the civics go
99-00 obd2b
Zulu451
Engine Management and Tuning
13
Feb 24, 2021 08:48 PM
killaek
Jun 27, 2010 04:34 PM
smackmybutter
Dec 31, 2005 10:31 AM
aw1234dude
Jun 24, 2003 04:12 PM
